270 Degree hinges
Forum topic by ware posted 05-11-2010 05:06 PM 7045 views 0 times favorited 6 replies Add to Favorites Watch
View ware's profile
ware
3 posts in 2936 days
05-11-2010 05:06 PM
I have a cabinet with a 1 3/4 inch face and full inset doors. I am looking for a hinge (?270 Degrees) that will allow the door to open and go to the side of the cabinet. I have been unable to find any that I think will accomplish this! Can you help?
Thanks!
Ware
View Michael Murphy's profile
Michael Murphy
453 posts in 3004 days
#1 posted 05-11-2010 05:18 PM
Here's one.
But if you mean you face is 1 3/4” wide and you want this door to flip around to the outside, I don’t think you are going to find anything that will work. Some European Hinges might swing around that far but not around a frame that wide
-- Michael Murphy, Woodland, CA.
View miles125's profile
miles125
2180 posts in 4004 days
#2 posted 05-11-2010 05:35 PM
You could mimic the face frame being there but in actuality having it attached to the door. I’ve done similar before and worked out pretty good. Otherwise you’re looking at a hinge needing a pivot point that would be unsightly in its needed protrusion from the cabinet.
-- "The way to make a small fortune in woodworking- start with a large one"
View davidpettinger's profile
davidpettinger
661 posts in 3199 days
#3 posted 05-11-2010 05:57 PM
You might try these guys. If they don’t have what you are looking for then I’m at a lose.
http://www.specialtysupplies.com/blum-m-5.html?page=18&sort=2a
-- Methods are many,Principles are few.Methods change often,Principles never do.
View ware's profile
ware
#4 posted 05-11-2010 06:10 PM
Thanks Miles125, but I do not understand what you are suggesting as an alternative!
Thanks!
Ware
miles125
#5 posted 05-11-2010 06:24 PM
Ware, I’m suggesting that when the door opens the face frame piece opens with it. Because it is part of the door. That way you have a door that really is even with the edge of the cabinet so you can get it to hinge back against the side like you want.
View ware's profile
ware
#6 posted 05-11-2010 06:50 PM
Thanks Miles125. In rereading your original post i can now see what you said, but I was not thinking along that line and could not picture what you were suggesting. Unfortunately, I have already attached the face to the frame.
Ware
