Replicable Wooden Ring Process?
Forum topic by Dustin posted 07-18-2016 03:05 PM 551 views 0 times favorited 3 replies Add to Favorites Watch
View Dustin's profile
Dustin
535 posts in 794 days
07-18-2016 03:05 PM
Topic tags/keywords: ring jig belt sander question trick tip sander lathe shaping turning
Hey, gang, coming to you today with a question that I haven’t really seen addressed here. I’ve been reading the forums for various methods on making wood rings (looking to do laminated rings with inlays, myself), and have seen a myriad of methods used: mandrels mounted to a drill press with a router and sprial cut bit mounted on the table, dremels, hand carving, belt sanders, etc. While reading all of this, I couldn’t help but think that there has to be an easier way to make such a simple shape.
What I’m proposing is this: after laminating my work pieces and cutting it to a rough shape (mainly to knock down the square corners), cutting multiple “mandrel” plugs to fit various ring sizes. Then building a little jig to allow me to mount the mandrel with the ring bored out, and use this to creep up on my Ridgid belt sander. Using a bolt or other veritcally mounted rod as an axis, spinning this mandrel with the ring blank by my belt sander to get the initial rounded shape.
I figured with the above method, the time consuming part would be the creation of all the different mandrel sizes. For finishing, I’m trying to come up with some idea to get a piece of rubber (or something flexible and “grippy”) with a center hole to ride on a pen mandrel on my lathe, with bolts or wing-nuts compressing the sides to have it expand and grip the ring better, allowing me to sand and finish the ring as I would pens.
Any thoughts on this, or has anyone had any success doing something similar? I’m looking for something that is repeatable and would be well adapted to doing multiple rings at once (plenty for friends, family, etc).
Thanks for reading!
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
3 replies so far
View Mutha's profile
Mutha
8 posts in 1032 days
#1 posted 07-18-2016 04:17 PM
Robert nurden on youtube has some videos up about ring making. He uses coins but he has a long stick looking thing on his lathe he uses to polish and shape the inside of his rings. It starts out big and is tapered. This could easily be modified with steps to accommodate the different ring sizes. Im assuming your drilling rings out of wood instead of using veneer. Anyway. GL snd i hope i helped a bit.
Dustin
#2 posted 07-18-2016 04:28 PM
Mutha,
As if I don’t spend enough time on youtube, now I get to prcrastinate on my homework even more tonight!
I’ll definitely check that out, as the insides is the part that was posing the biggest problem. Prior to this suggestion, I was contemplating putting the ring in a chuck (wrapped, of course, to protect the finish) and delicately sanding through my usual finishing schedule.
Thanks again for the tip!
Mutha
#3 posted 07-18-2016 06:07 PM
Lol yeah be careful, i find his videos to be quite entertaining, easy way to burn thru 10 minutes or 3 hours. https://youtu.be/hjdq_6VxnXo will get you to one video with him polishing the inside of one of his rings. I want to make some rings but think i want to use veneer. The drunken woodworker had an excellent video about using veneer for rings.
