Unsure if this joint would be safe?
« back to Joinery forum
Forum topic by cheramello posted 07-17-2016 06:02 PM 776 views 0 times favorited 14 replies Add to Favorites Watch
View cheramello's profile
cheramello
4 posts in 678 days
07-17-2016 06:02 PM
I am building some simple shelves for garage storage. I got the idea from Ana White I don’t know if others have designed this as well. The problem is I am using free wood and the longest 2×4’s I have are 6 foot and I’m kind of cheap so I don’t want to buy longer boards if I don’t need to. My shelves will span 101 inches wide. I have a Kreg type jig and am wondering if making pocket holes in the ends of the 2×4 to connect them the long way would be safe to hold the weight I’m going to put on this shelf? My studs are 16” except on the ends they go out to 18”. I’m not really sure if this type of joint/idea is strong enough. I don’t have any other type of joiner tools. My little drawing shows the ends of the 2×4’s and the red lines would be where I want to insert the pocket holes and screws.
-- I'm just a novice woodworking hobbyist who likes to build things for fun! :)
14 replies so far
View bondogaposis's profile
bondogaposis
4727 posts in 2350 days
#1 posted 07-17-2016 06:50 PM
I think that joint will fail if you put any kind on weight on it. You really are cheap, a 10ft 2×4 costs $4.35 in my area.
-- Bondo Gaposis
View MrUnix's profile
MrUnix
6714 posts in 2198 days
#2 posted 07-17-2016 07:00 PM
101 inches is about 8.5 feet… so if you only have 6’ 2×4’s, you could split that in half and make each long run in the front out of two 4.25’ pieces secured to the vertical supports on each end.
View Ted78's profile
Ted78
382 posts in 1999 days
#3 posted 07-17-2016 07:21 PM
MrUnix I think has the right idea. joining boards end to end with any kind of strength is quite difficult. Just put an upright support in the middle of the shelf so each board only has to span half of the 101” Even with a continuous length of 2×4 I would want it supported in the middle for a shelf that long. To span 101” with only support on each end I’d use boards a lot wider than 4”
-- Ted
View clin's profile
clin
842 posts in 995 days
#4 posted 07-17-2016 07:36 PM
Put that joint in the middle where it can be supported by the center support. However, each side will sag more than it would with a solid piece. But I see no reason you can’t take a shorter piece and double if over the joint. That extra piece would be hidden by the plywood on the shelf.
No point in pocket screws in this case either. Just butt the two together and overlap with 2’+ long piece and I think you’d be good. Note: You still need that center support.
-- Clin
View nkawtg's profile
nkawtg
276 posts in 1250 days
#5 posted 07-17-2016 07:44 PM
2×4’s are dirt cheep, use the shorter pieces for everything but the long runs.
You should only need three 8’ 2×4’s that cost something like $3 a piece.
cheramello
4 posts in 678 days
#6 posted 07-17-2016 10:25 PM
Thank you everyone! I had planned on putting an additional vertical support in the center. I talked with a few other people and they suggested to alternate the rail pieces on the back wall (6’ and then the 29” for the other piece) instead of just straight in half so I could maximize support from the studs. I will try doubling up the joints for the front but I’m not so cheap that I won’t buy three 2×4’s if I need them. I just like to be frugal, if I have something for free why pay for extra that’s all.
cheramello
4 posts in 678 days
#7 posted 07-17-2016 10:27 PM
VERY STUPID POST
- GR8HUNTER
Then why even bother replying? We all start somewhere, I’m sorry for you that you don’t remember being new at this stuff and having questions. Even people with advanced skill in their field learn new things often.
View Gixxerjoe04's profile
Gixxerjoe04
850 posts in 1575 days
#8 posted 07-17-2016 10:31 PM
why 101 inches? Could go get 8 foot 2×4’s for like $2.40 a piece or something like that
cheramello
4 posts in 678 days
#9 posted 07-17-2016 10:48 PM
why 101 inches? Could go get 8 foot 2×4 s for like $2.40 a piece or something like that
- Gixxerjoe04
I’m putting the shelves along the back wall of my garage and that’s how wide it is. Hence the weird dimensions!
View realcowtown_eric's profile
realcowtown_eric
609 posts in 1936 days
#10 posted 07-17-2016 11:36 PM
Borrow a wood stretcher from someone, or take a look at Japanese joinery book.
Rip the 2×4 ’s and relaminate them to make them longer
or just buy longer 2×4’s
Eric
-- Real_cowtown_eric
View patcollins's profile
patcollins
1685 posts in 2864 days
#11 posted 07-17-2016 11:43 PM
Pocket hole screws are meant to grab in side grain not end grain, especially in soft construction lumber.
http://www.woodmagazine.com/woodworking-tips/techniques/joinery/pocket-hole
View rwe2156's profile
rwe2156
2925 posts in 1479 days
#12 posted 07-18-2016 12:09 PM
Cut them 50 1/2” each, put joint in middle. The 22” left you use for x pieces.
Pocket holes no good for something like this.
Use these type screws, not flat heads.
View dbray45's profile
dbray45
3320 posts in 2775 days
#13 posted 07-18-2016 12:23 PM
Pocket screws are not made of this kind of service.
I use 1/4” to 1/2” carriage bolts
-- David in Damascus, MD
View Nubsnstubs's profile
Nubsnstubs
1287 posts in 1729 days
#14 posted 07-18-2016 01:22 PM
VERY STUPID POST
- GR8HUNTER
Then why even bother replying? We all start somewhere, I m sorry for you that you don t remember being new at this stuff and having questions. Even people with advanced skill in their field learn new things often.
- cheramello
I love how you defended yourself. So far, this is the best defense I’ve seen. It’s gonna make my day. It’s brilliant!
You’ve gotten good advice, now it’s just a matter how you put it all together. The lumber you got can be used can be used, so go for it and post a picture when the project is done. ............... Jerry (in Tucson)
