Z-chair
Forum topic by richgreer posted 05-10-2010 06:46 PM 2899 views 0 times favorited 13 replies Add to Favorites Watch
View richgreer's profile
richgreer
4541 posts in 3071 days
05-10-2010 06:46 PM
It’s probably a little tacky to reference a project from another website on this website. Nonetheless, I always get good feedback from other LJs on this site.
I really like this chair design and would like to build some for my screen room – -
http://www.finewoodworking.com/item/21248/z-chair
What I cannot figure out from the listing is how the joints were done. Those joints have to be very strong. I think I would do half-lap joints with a couple of hardwood dowels for reinforcement. I’m wondering if anyone can opine on the best way to do these joints.
As an FYI – I would not use red oak since I want it to withstand the weather. I would probably use ipe if I can find it or white oak if I cannot.
13 replies so far
View Michael Murphy's profile
Michael Murphy
453 posts in 3002 days
#1 posted 05-10-2010 06:54 PM
Cross lap or Mortise and tenon, but I would have a hard time trusting something that narrow in wood. Especially the 4/4 it appears to be built out of. All it would take would be someone large to sit down hard and they would be on the floor. Putting a cross member the other way kind of defeats the design but it would be quite a bit stronger.
-- Michael Murphy, Woodland, CA.
View Jon Spelbring's profile
Jon Spelbring
199 posts in 4250 days
#2 posted 05-10-2010 07:05 PM
I think there’s a similar one on one of the Festool sites – they of course, use the Domino for the joinery.
-- To do is to be
View AaronK's profile
AaronK
1506 posts in 3461 days
#3 posted 05-10-2010 07:45 PM
it’s posted as a “one day project” – i think your best guess is probably it, rich.
it could even be screws – driven in at an angle from the horizontal members. the seat would hide the top ones, and the bottom ones would be against the floor.
richgreer
#4 posted 05-10-2010 08:09 PM
After reflecting on this – - I think I want to get some 6/4 stock. On 3 of the 4 pieces, I will trim them down to 3/4 with a flare at one end back to 6/4. I will cut a slot in the 6/4 end that will accept the next 3/4 piece. I will also put hardwood dowels through the joint.
A while ago I was building a chair and I checked on some standards for chair construction. I read that a chair should be able to withstand dropping 250 pounds from 2’ above the chair. I wonder if this chair could pass that test.
117091 posts in 3574 days
#5 posted 05-10-2010 08:16 PM
I would guess half lap at the angels I agree with Michael that this chair is made as a design statement rather than a sturdy piece of furniture. A wood like Epi would make it much stronger.
View uffitze's profile
uffitze
199 posts in 2952 days
#6 posted 05-10-2010 08:17 PM
Personally, I think that I’d use a mortise and tenon, and I’d probably make it stepped and pegged if I was at all worried about failure of the joint.
A lap joint might work, and if I wanted to make the chairs as a production run, I’d experiment with it. Again, I’d almost definitely peg a lap joint to make sure the chair doesn’t collapse if the glue fails.
View miles125's profile
miles125
2180 posts in 4002 days
#7 posted 05-10-2010 09:16 PM
Needs cleverly disguised STEEL at that intersection for sure. I don’t see any wood only joint standing the test of time, kids and chubby people. :)
-- "The way to make a small fortune in woodworking- start with a large one"
View SnowyRiver's profile
SnowyRiver
51457 posts in 3477 days
#8 posted 05-10-2010 09:26 PM
My vote is mortise and tenon. You could use a pin or wooden peg through the joint to strenghten it also.
-- Wayne - Plymouth MN
View Dave Owen's profile
Dave Owen
254 posts in 3071 days
#9 posted 05-10-2010 09:46 PM
Without a doubt, it is an interesting design – and the designer is to be congratulated for originality. If I were going to try to make one, I’d consider a pinned bridle joint. Still, it strikes me more as being more than a little risky – especially in 4/4 wood. In addition to possible problems with the joint, the angled legs would be subject to a lot of bending stress. If anything did fail, it could be a nasty fall. Put another way – if you’ve made any when I come to visit, I might just pull up a kitchen chair.
-- Dave O.
Michael Murphy
#10 posted 05-10-2010 09:51 PM
Add a couple of gussets if it doesn’t compromise your design.
<redpre#1></a>Photobucket
View woodpeckerbill's profile
woodpeckerbill
205 posts in 3270 days
#11 posted 05-10-2010 10:37 PM
Rich, woodcraft magazine had a project a while back. A Z chair. It was joinered with the domino system. Think woodcraft was pushing the domino tool back then. Anyway it was very strong! Might want to check it out.
Bill
richgreer
#12 posted 05-10-2010 10:56 PM
Thank you everyone for the great ideas and suggestions. I like the gusset idea that Michael provided and I don’t think it would compromise the design. What would anyone compare this to.
I also like the idea of using ipe. I’ve worked with ipe in the past and I am very impressed with how strong it is. Of course, in this application, strong wood is only half the issue. The other half is a strong joint. That is where the gussets come in. With ipe wood and strong joints (including the gussets) I would gladly plop my 200 lbs. down on this without a reservation.
I’m going to try one. I’ll keep everyone posted. Think I will place an order for some ipe today.
View AlaskaGuy's profile
AlaskaGuy
4133 posts in 2306 days
#13 posted 10-08-2014 06:26 PM
Could be something like in this video.
https://www.youtube.com/watch?v=XPudD4vtscQ&list=PLCB6AEE2BAF8A0464&index=9
