Sand down end grain without rolling over corner
Forum topic by treesner posted 07-16-2016 09:29 PM 1406 views 0 times favorited 16 replies Add to Favorites Watch
View treesner's profile
treesner
167 posts in 929 days
07-16-2016 09:29 PM
How do you sand down end grain without rolling over the edge? I tried chiseling it down and block planing it on a few before sanding but the plywood end grain doesn’t plane that well
16 replies so far
View AandCstyle's profile
AandCstyle
3027 posts in 2222 days
#1 posted 07-16-2016 09:59 PM
Trees, clamp a piece of scrap to each side of the piece at the desired level. Make pencil lines on the scrap and stop sanding when you notice the pencil disappearing. This will be easier if you are able to remove the piece from your assembly. HTH
-- Art
View joey502's profile
joey502
525 posts in 1483 days
#2 posted 07-16-2016 10:27 PM
Stacking boards together and sanding as Art mentioned above works well if the parts are not assembled. You should be able to clamp more pieces to the part in your picture and get better results than your second pic.
Sanding the edges by hand works well too. I sometimes put the sand paper on my bench or table and run the board over it, work pretty well. Similar motion to edge jointing a board. Again this is before the parts are assembled.
I find my end result is much better when i sand and break the sharp corners before assembly.
View bbasiaga's profile
bbasiaga
1200 posts in 1960 days
#3 posted 07-16-2016 10:36 PM
Card scraper?
Brian
View Jbay's profile
Jbay
2228 posts in 864 days
#4 posted 07-16-2016 10:42 PM
Honestly, you should have noticed them being off before you built it.
Stack all your pcs next to each other and it would have shown, or dry fit them first and it would have shown.
Then you could have run them all back thru the saw taking off what ever was needed to make them all the same.
A good sanding block with 100 grit should knock it down. I use a 3/4” block with a 4×24 sanding belt wrapped around it tight.
treesner
#5 posted 07-16-2016 10:45 PM
- jbay
It’s off because the glue up, shifted
I guess I could use even more clamps to pull that down?
View Jbay's profile
Jbay
#6 posted 07-16-2016 10:54 PM
Well, It won’t take too many times to correct that.
Lesson learned,
View bobasaurus's profile
bobasaurus
3405 posts in 3149 days
#7 posted 07-16-2016 11:25 PM
I would use a sharp low angle block plane held at a skew angle to level that off.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View rwe2156's profile
rwe2156
2881 posts in 1446 days
#8 posted 07-16-2016 11:35 PM
^^^Yes!!!
You do it buy using the right tool!!
For something like what you’ve show, I would use a tablesaw to trim it down. Sneak up on it!
View Tootles's profile
Tootles
808 posts in 2467 days
#9 posted 07-17-2016 03:46 AM
I’d use a block plane to remove most of what you need to take away and then I’d hand sand it at the end – using a simple sanding block and paper, not a sanding machine. You could probably use a cork block without problem, but if flatness / not rolling over is your main concern, just use a scrap of wood. Its flatness and hardness will help prevent rounding the corners, just as long as you keep it in even contact with the edge that you are sanding.
-- I may have lost my marbles, but I still have my love of woodworking
View JBrow's profile
JBrow
1348 posts in 885 days
#10 posted 07-19-2016 03:32 PM
treesner,
I hate the thought of sanding, planing, or scrapping. It is a slow go and joining a sanded or planed edge to a face frame could be difficult.
An alternative not yet unmentioned approach is to clamp a straight edge flush to the edges at each end and then use a router with a pattern bit to flush up the edges of the box. A wide straight edge would keep the clamps out of the way while holding the straight edge in place. The inexpensive pattern bits with cutting edges parallel to the shank of the bit would work but could produce some tear out. Much more expensive spiral compression pattern bits, according to manufacturers, greatly reduces tear out; however, since I have yet to add this bit to my collection I am unable to verify or refute manufacturers’ claims. A spiral up cut bit in the router outfitted with a guide bushing would also reduce tear out, but set up would be more difficult since the straight edge would have to be offset.
View bondogaposis's profile
bondogaposis
4683 posts in 2316 days
#11 posted 07-19-2016 03:44 PM
Don’t sand, use a block plane.
-- Bondo Gaposis
View HokieKen's profile
HokieKen
4737 posts in 1103 days
#12 posted 07-19-2016 05:01 PM
- bobasaurus
Yep^. I’ve used it on plywood with no problems. Gotta be sharp though.
-- Kenny, SW VA, Go Hokies!!!
View MrRon's profile
MrRon
4714 posts in 3208 days
#13 posted 07-19-2016 10:01 PM
That’s what router trim bits are for. If you want to sand end grain, use a stationary disc sander.
Smitty_Cabinetshop
15280 posts in 2583 days
#14 posted 07-20-2016 01:37 AM
Answers ranging from router/jig/pattern bit, to dragging the cabinet across a table saw, to hand sanding, to block plane, to sanding with doubler blocks in place. Quite the range of answers.
I’d also vote sharp block plane. It’d make short work of the problem, and not prove difficult to joint face from to if done with any care at all.
View Aidan1211's profile
Aidan1211
198 posts in 791 days
#15 posted 07-20-2016 11:26 AM
Planes when tuned and sharpened will slice that plywood no problem and a lot cleaner than sanding. another option if you want is to match a piece of ply level with where you want it to end up and run a up spiral flush trim bit. Gotta be razor sharp and i’d probably climb cut to prevent any little buggers chipping.
-- its better to plan on the task at hand than actually doing it........ You look smarter.
