Seeking advice on some cherry
Forum topic by AudibleVelvet posted 07-15-2016 01:30 PM 590 views 0 times favorited 4 replies Add to Favorites Watch
View AudibleVelvet's profile
AudibleVelvet
19 posts in 863 days
07-15-2016 01:30 PM
Topic tags/keywords: drying help cherry
Hello all. Someone gave my dad this cherry and I became the steward of it. He had it outside with the bark still on under a small maple tree. Not sure exactly how long ago it was cut, but fairly recent (I think days, not weeks). The smell under the bark was awesome! What is the best thing to do to set up to dry and get usable wood? He wants two of the four as rustic benches. I want to take what I can get for a couple boards. Can I use some old paint to seal the ends? Should I?
Thanks.
View bigblockyeti's profile
bigblockyeti
5257 posts in 1896 days
#1 posted 07-15-2016 01:49 PM
A paraffin wax would be better for sealing the ends to reduce cracking. If you’re going to air dry it, plan on 1 year drying time per 1” of thickness before you try to use the wood for any projects.
AudibleVelvet
#2 posted 07-15-2016 01:56 PM
Should I cut it down first or dry as is?
bigblockyeti
#3 posted 07-15-2016 02:05 PM
I see you want some of it cut into boards, that I would mill ASAP then stack and sticker it. Are the half logs going to remain close to that shape for the rustic benches?
View GR8HUNTER's profile
GR8HUNTER
4928 posts in 888 days
#4 posted 07-15-2016 03:38 PM
If you do wax ends ….....Make sure it is a nicer cut then chainsaw
