TREX on a Sawstop?
Forum topic by Scott posted 05-09-2010 06:34 PM 1873 views 0 times favorited 7 replies Add to Favorites Watch
View Scott's profile
Scott
153 posts in 2936 days
05-09-2010 06:34 PM
Topic tags/keywords: question
Does anyone know for sure if it is okay to cut TREX decking on a Sawstop? I think it’s probably okay, but just wanted to make sure before I put it in bypass mode.
Thanks!
7 replies so far
View MedicKen's profile
MedicKen
1612 posts in 3426 days
#1 posted 05-09-2010 06:57 PM
I dont see why it wouldnt be. The TREX will be a plastic material and is a better insulator than conductor. I say go for it
View barryvabeach's profile
barryvabeach
159 posts in 3008 days
#2 posted 05-09-2010 07:05 PM
Scott, you can touch it to the blade , with power to the switch on but the power to the blade off, and if it will cause a trip, the green light will turn to red. If you are cutting a bunch of it, call SS customer service, because I thought there was a material that tends to stick to the sensor, and I don’t recall if it was trex or not . but IIRC there was a suggestion about how to avoid a problem. If you are only cutting a little, and you don’t want to take any chances with a false trigger, you can always use bypass mode
View dbhost's profile
dbhost
5705 posts in 3196 days
#3 posted 05-09-2010 07:42 PM
Try it, if it causes an accident, sue…
View rance's profile
rance
4255 posts in 3125 days
#4 posted 05-09-2010 07:43 PM
Alternatively, you can always temporarilly turn off the detector. I do this when cutting particurlarly wet wood. OTOH, I’ve accidently cut through a couple of finish nails and NOT tripped the detector. I’m sure it was because there was not a path from the nail to my body.
View JJohnston's profile
JJohnston
1622 posts in 3255 days
#5 posted 05-09-2010 08:05 PM
I just cut some yesterday for lawn border and stakes. No problems, bypass mode not necessary.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
Scott
#6 posted 05-09-2010 08:29 PM
Thanks for the replies. My concern is that TREX is very dense and they use a resin with the sawdust so I didn’t want the SS to trip because of that.
I made 2 cuts yesterday in bypass mode but then I figured that it kind of defeats the purpose of me having the SS in the first place. It’s nothing urgent, so I may call or email SS to be absolutely sure.
I would have to sue SS and Trex if anything bad were to happen. ;-)
27250 posts in 3786 days
#7 posted 05-10-2010 12:56 AM
I agree that it shouldn’t be a problem. I have been putting down bamboo floor and cutting the flooring on mine. Basically the flooring is very dense mixture of bamboo sawdust and epoxy resins.
