Complicated glue-up
Forum topic by Stevinmarin posted 05-08-2010 11:35 PM 3493 views 0 times favorited 33 replies Add to Favorites Watch
View Stevinmarin's profile
Stevinmarin
838 posts in 3161 days
05-08-2010 11:35 PM
Topic tags/keywords: chair model
Thanks everyone who has has input in my triangle cutting question. I think I’ve got a handle on it by spending hours fussing with my crappy miter guage.
Let me show you what I’m doing and ask for more help. The Marin County Fair is in July and they always have a chair-making competition. There is a “miniature” category…chairs under 12” that I am entering.
Here’s an actual chair I found in a design book that I want to make out of wood. The one pictured is made out of aluminum:
Chair
I am going to use 1/4” wood for this. The question is, how can I clue it up? There are a ton of angles to deal with. For instance, about a 50 degree angle where the seat meets the back. Then the angles where the back legs meet the back. Of course, I am even fretting over the simple 45 degree glue-up where the seat meets the front leg. Quarter inch thick wood!
Again, it won’t take any stress…it’s a 12” model. Any suggestions?
-- Entertainment for mere mortal woodworkers. http://www.WoodworkingForMereMortals.com
33 replies so far
View MedicKen's profile
MedicKen
1615 posts in 3548 days
#1 posted 05-08-2010 11:38 PM
Cut a complementary angle to what you are gluing so you can get the pieces clamped at 90 degrees?
117179 posts in 3663 days
#2 posted 05-09-2010 12:28 AM
Are you suppose to sit in the chairs you make? If so 1/4” ply will be a rough route to go.
View mtnwild's profile
mtnwild
3474 posts in 3613 days
#3 posted 05-09-2010 12:31 AM
Finger joints. Only thing I think would be strong enough. Would look cool too.
View Michael Murphy's profile
Michael Murphy
453 posts in 3091 days
#4 posted 05-09-2010 12:36 AM
Bent laminations. 5 or 6 layers of 1/28 ” veneer over a form.
-- Michael Murphy, Woodland, CA.
Stevinmarin
#5 posted 05-09-2010 12:39 AM
Jim: no, this chair will just be a miniature…basically an art piece 12” tall. It doesn’t need to be very strong. I do want it strong enough that I can round over the joint edges. I may just do that with my sander.
Heer’s a crazy idea…how about super glue? Do you think it will hold solid wood pieces together? That way I wouldn’t need to clamp it…just hold the pieces together for a few seconds. I may put some phony splines in the joints just to make it all fancy-like.
Stevinmarin
#6 posted 05-09-2010 12:42 AM
Michael , your idea is interesting. Will veneer bend into these angles? I could certainly make a plywood form. Okay…ignorance check…I’ve never used veneer before.
#7 posted 05-09-2010 12:43 AM
I think Michael Murphy has the right Idea but you could give the super glue a try.
#8 posted 05-09-2010 12:46 AM
Another approach might be to have the joinery area were the seat is being thicker and tapering down to a 1/4”
at the feet.
View richgreer's profile
richgreer
4541 posts in 3160 days
#9 posted 05-09-2010 01:12 AM
For wood to wood gluing, superglue will not give you any advantage over a good wood glue. I would use Gorilla wood glue. You’ll be impressed with how will it holds if it is glued properly. Furthermore, you will want some open time when doing this glue up. Superglue gives you virtually no open time.
I think finger joints would be your best option. However, I see a problem with the back. You really want the grain to run into the fingers (not across the fingers). At the back you need joints on the bottom and the sides. I think there is a way to solve that problem by making the back out of three pieces that you glue together.
I would discourage you on veneer. It would be real hard to get the edges to look right. I would go with a good stable hard wood. My first choice would be maple.
View Broglea's profile
Broglea
685 posts in 3176 days
#10 posted 05-09-2010 01:12 AM
Steve – I think your on to something with the super glue. For example, if you are try to glue up one of the angle you could try to use super glue on half of it and wood glue on the other half. That way once the super glue takes hold it will hold the angle until the wood glue cures.
View JJohnston's profile
JJohnston
1622 posts in 3377 days
#11 posted 05-09-2010 01:24 AM
Is the original bent from a single sheet of aluminum? If so, I think laying up veneers is probably your best bet. Granted, I’ve never laid up veneers, but it’s really not that complicated a shape. I see only 4 bends. Someone of your skill level could certainly turn out male and female molds for this.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
16276 posts in 4304 days
#12 posted 05-09-2010 01:33 AM
I realize this will change the look, but it crossed my mind that you could use decorative molding. like 3/4” cove, as glue blocks at the inside corners. With a little imagination, I think it could be blended in.
View rance's profile
rance
4260 posts in 3246 days
#13 posted 05-09-2010 02:06 AM
Finger joints, Gorilla glue, and the cove molding with the meat cut off to act like a fillet on the underneath side. Super glue is too brittle to hold this IMO. GG has some give to it when it is cured, more so than yellow glue. Because of the angles, you may consider hand cut dovetails rather than finger joints. Actually an angled finger joint would be sufficient, and easier than hand cut.
Keep us updated on your progress.
View JuniorJoiner's profile
JuniorJoiner
487 posts in 3526 days
#14 posted 05-09-2010 02:18 AM
I am going to say bent lamination veneer as well, just realize that you are bending the veneer in multiple axis, which may require hot pipe bending before you laminate.(because grain direction will be an issue)
for a 12” chair, you may even be able to put it in a vacuum press.
-- Junior -Quality is never an accident-it is the reward for the effort involved.
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3201 days
#15 posted 05-09-2010 02:45 AM
junior says it 5-6 layer of venner steambend over a pipe in the right angle
and glue it up in a male/female mold
that´s how they do it here in Denmark with steambend furniture
look forward to see what you come up with
Dennis
showing 1 through 15 of 33 replies
