Brad Nailer Under Water
« back to Hand Tools forum
Forum topic by AliceAforethought posted 07-13-2016 08:17 PM 578 views 0 times favorited 8 replies Add to Favorites Watch
View AliceAforethought's profile
AliceAforethought
13 posts in 1416 days
07-13-2016 08:17 PM
Hi guys,
Recently my home was flooded, my Porter cable BN200C nailer was under water for a few hours. So was the compressor. I tried to get out as much water as possible out of the compressor, and simply used the nailer to get moisture out of it. Lots of liquid came out as each brad was popped. My question is…do I need to to do more? Take thing apart? Are there any instructions online that show how to get rid of any lingering moisture that might be in the nailer?
Thanks.
8 replies so far
View MrUnix's profile
MrUnix
6933 posts in 2344 days
#1 posted 07-13-2016 08:25 PM
If it were mine, I’d take it apart as much as possible… then clean and spray down everything in sight with some WD-40 to displace any remaining moisture. Then a good long session running extra pneumatic oil through it just for good measure. What you did was probably sufficient – I just like taking things apart :)
AliceAforethought
#2 posted 07-13-2016 08:37 PM
Mind you, I have never opened the top of one of these, but I just did…should i see any moisture of any kind in that “chamber?”
View bigblockyeti's profile
bigblockyeti
5228 posts in 1866 days
#3 posted 07-13-2016 09:09 PM
They aren’t too complicated to disassemble. Just to be safe it wouldn’t be a bad idea to have a schematic handy if reassembly gets tricky. Wipe down everything with a dry rag or towel and apply a little air tool oil to everything before putting it back together. I’d cycle it several times before doing any work that could be damaged or stained by a little oil mist in the exhaust. Beyond that, just using it will help to get any water out that you can’t readily get to.
View Loren's profile
10477 posts in 3793 days
#4 posted 07-13-2016 10:24 PM
As mentioned, they aren’t complicated but the metal
parts inside are not made of stainless steel so rust
is likely if you leave it wet for too long.
They are designed to handle condensed water in
the air lines. It happens. Name brand nailers
are pretty robust in my experience.
View rwe2156's profile
rwe2156
3091 posts in 1626 days
#5 posted 07-14-2016 12:38 PM
I would fill it with WD40 and see if it will shooting.
After shooting about 50 nails I would put quite a bit of oil in it and keep using it every day for a few days.
But to do it right you’ll have to take it apart and dowse everything in WD40.
They really aren’t that complicated. I’ve fixed a couple and was surprised how simple they are.
Have a parts diagram handy! Take pics when you break it open.
View Tim's profile
Tim
3812 posts in 2107 days
#6 posted 07-14-2016 04:57 PM
Yup WD-40. This is what the stuff is actually meant for.
View greyspider's profile
greyspider
94 posts in 3069 days
#7 posted 07-22-2016 08:20 AM
When disassembling anything, I always use my phone to take pics so I can put it back together. Saved my bacon more than once.
View Redoak49's profile
Redoak49
3525 posts in 2134 days
#8 posted 07-22-2016 11:34 AM
The greatest use for a phone is taking pics as you take something apart. Can not take enough pictures.
