Polyurethane turning white
Forum topic by Sandro posted 05-08-2010 02:44 AM 15372 views 0 times favorited 7 replies Add to Favorites Watch
View Sandro's profile
Sandro
6 posts in 3468 days
05-08-2010 02:44 AM
I am painting an old wooden handrail. I gave a couple of coats of stain and a couple of coats of polyurethane. I waited at least 24 hours between each two coats. Everything went well until I decided to give yet another coat of polyurethane. That polyurethane immediately turned white in several places.
I have read that humidity causes polyurethane to turn white. However I didn’t use any water, and I believe the humidity level in my garage is pretty normal. I used one brush for the stain and a different brush for the polyurethane. I clean the brush with thinner each time and save it inside a zip-locked plastic bag wrapped in a paper towel moistened with thinner, so it doesn’t dry.
Could the thinner remaining in the brush have caused the problem? Or is water the only thing that makes polyurethane turn white? And why did this happen only once?
Thanks!
7 replies so far
View SnowyRiver's profile
SnowyRiver
51457 posts in 3448 days
#1 posted 05-08-2010 02:52 AM
Yes, water and thinner will cause the poly to turn white. It could be that the brush was getting more saturated with thinner as you did each coat and it finally showed up. When I clean the brush with mineral spirits I always snap the brush a few times at the ground (outside of course) after cleaning it to throw off any residue and I leave it out in the open so the thinner evaporates off the brush.
-- Wayne - Plymouth MN
Sandro
#2 posted 05-08-2010 03:34 AM
Thanks, Wayne.
Now I am wondering how I can get the white polyurethane back to its normal state.
View Bureaucrat's profile
Bureaucrat
18339 posts in 3620 days
#3 posted 05-08-2010 03:42 AM
The only way I know of to get rid of the white is sanding, bummer.
-- Gary D. Stoughton, WI
SnowyRiver
#4 posted 05-08-2010 04:46 AM
Sanding may be the best way although depending on how deep the white is, sanding could be quite a job. The only other thing I could think of would be to use a paint stripper and see if that will remove all of the poly, then start over.
Sandro
#5 posted 05-08-2010 06:33 PM
Fortunately the white was very shallow, and it went away with just a little sanding. Thanks guys!
View Smooth's profile
Smooth
2 posts in 222 days
#6 posted 09-14-2017 07:30 PM
EASY fix!! Just take a standard blow dryer to it. It takes a little time, but works like magic and stays fixed. Mixwax really needs to add this tip to their label and save people a lot of extra, unnecessary work.
Smooth
2 posts in 222 days
#7 posted 09-18-2017 07:31 PM
*Note on my previous comment – I did this outside (in the shade) when the temp was in the 90s. It didn’t work so well when temp was in the mid 70s.
