| Forum topic by ben | posted 340 days ago | 656 views | 0 times favorited | 14 replies | ![]() |
340 days ago |
I finally had need to put my recently purchased, used jet bandsaw to use, so I did my best impression of a bandsaw tune up… aligning the wheels in plane, correcting all the alignment blocks, etc. I installed what I would call either a 1/4” blade (came with 3 blades: 3/4”, 3/8” and 1/4”). The blade was peeling a little paint (or something else?) off the sides, but seemed to run fine. In any case, I found that the blade leaves a small zig zag pattern as I cut. The faster the feed rate, the longer the zigs and zags, but it’s present nonetheless (unless I go ridiculously slow). Is this due to the blade, or due to my saw (mis)tune-up, or something else perhaps? Does anybody have any suggestions on what blades to buy? Everything I’ve read says timberwolf blades are the best brand for hobbiests, so the real question becomes width, tpi, etc. At the moment, I expect to have 3 main uses: general/curved cutting, ripping stock, and occasional resawing. At the moment this would be mostly on cherry, but other hardwoods will get cut, and some pine now and then. Finally, my guide blocks need to be replaced—are cool blocks the way to go? I don’t need to spend tons of money on a guide system… Any and all bandsaw tips are appreciated… Until this month, I hadn’t used a band saw since high school… Thanks! -b |
