Toy box bottom selection
Forum topic by avsmusic1 posted 07-13-2016 03:17 PM 576 views 0 times favorited 11 replies Add to Favorites Watch
View avsmusic1's profile
avsmusic1
256 posts in 681 days
07-13-2016 03:17 PM
I’m building my son a toy box and I’m hoping for some guidance. I’m planning to use a dado blade to cut a channel on all four sides and “float” the bottom. I’m using red oak for the rest of the build but not sure what to use for the bottom. I suppose I really have 3 options.
1. I probably have enough scrap to glue up a bottom out of oak
This option is certainly the most work and I presume it would have the most movement, but it would look lovely
2. I can buy a 2’ by 4’ section of 3/4” birch ply from my local big box store
This is a cost effective option and very quick, but would disrupt the look and I don’t know if I trust ply/wood from from the big box store (anyone with experience here?)
3. I can buy a full sheet of higher quality red oak 3/4” ply from the mill I’ve gotten the oak from
The most expensive option and I’d have a ton of left over with minimal storage space, but it’s easy and maintains the look
So I guess the question is – what would you do?
11 replies so far
View JohnDon's profile
JohnDon
66 posts in 1165 days
#1 posted 07-13-2016 04:14 PM
I’d go with plywood- it’s going to be covered with toys, so you won’t see it much, anyway! You could stain it to more or less match the oak. I think 3/4” would be way overkill- you’re not building a floor- 1/2” should be plenty strong. Sorry, I don’t have any experience with the big box birch ply, but my guess is that 1/2” Baltic birch ply would be as strong, and not as heavy.
View johnstoneb's profile
johnstoneb
2914 posts in 2168 days
#2 posted 07-13-2016 04:16 PM
1/2” ply of any kind would work fine. 3/4” is overkill. Plywood from the box stores is fine the main problem with is is voids that show on the edges. Birch ply will have fewer voids than the construction grades.
-- Bruce, Boise, ID
avsmusic1
#3 posted 07-14-2016 12:56 PM
Thanks gentlemen – I was kind of hoping that would be the consensus
I just realized I didn’t give dimensions but my project isn’t huge. It’s going to be roughly 3’x2’. Still stick with 1/2 ply?
JohnDon
#4 posted 07-14-2016 03:33 PM
yep. if you’re really concerned, you can make the dado high enough from the bottom edge- say 3/4”- that you can always glue some battens on the under side of the bottom. I don’t think it will be necessary, though.
View GR8HUNTER's profile
GR8HUNTER
3819 posts in 708 days
#5 posted 07-14-2016 03:38 PM
I know 1/2” would be fine ….. but if your worry about it …....... just hot glue a 4×4 in the center…... length TBD
-- Tony Reinholds,Pa. REMEMBER TO ALWAYS HAVE FUN
runswithscissors
2751 posts in 2021 days
#6 posted 07-16-2016 05:04 AM
Or maybe mill tongue and groove edges on your boards, and install them loose in the rabbets at ends and sides. Being loose means no worries about shrinking and swelling.
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3708 days
#7 posted 07-16-2016 07:38 AM
I’d say 1/2” is good to so even if the little one climbs in with all the toys the bottom won’t drop out. I would be concerned with loose panels pinching little fingers or legs as they shift around inside the rocket ship/cave/toybox
avsmusic1
#8 posted 07-16-2016 01:52 PM
If I go ply I could cut any panels pretty snug b/c the expansion wouldn’t be as bad, right? Alternatively, I’m thinking of putting something in the groove to prevent shifting (eg. weatherstripping)
View BurlyBob's profile
BurlyBob
5491 posts in 2261 days
#9 posted 07-16-2016 02:23 PM
I’ve used a small dab of silicon caulk in dados and picture frames to reduce shifting and movement. Might be an option for you.
GR8HUNTER
#10 posted 07-16-2016 03:11 PM
If I go ply I could cut any panels pretty snug b/c the expansion wouldn t be as bad, right? Alternatively, I m thinking of putting something in the groove to prevent shifting (eg. weatherstripping)
- avsmusic1
that is correct plywood is a lot more stable then hardwood …...1/2 inch would be plenty strong enough
I ve used a small dab of silicon caulk in dados and picture frames to reduce shifting and movement. Might be an option for you.
- BurlyBob
and also do this with caulk about an inch bead on all 4 sides ….. just make sure it is silicon
avsmusic1
#11 posted 07-16-2016 10:07 PM
Thanks again guys!
