Question
« back to Coffee Lounge forum
Forum topic by GMman posted 1107 days ago 727 views 0 times favorited 8 replies Add to Favorites Watch
View GMman's profile
GMman
3882 posts in 1864 days
1107 days ago
Topic tags/keywords: question
How can I split a 2×4x8 diagonally so I would have 2 pieces 2in. at one end and 0 at the other end?
Besides using a circular saw.
8 replies so far
#1 posted 1107 days ago
That can be done on a table saw using a taper sled or it can be done on a band saw without a sled.
d
-- The best things in life aren't THINGS.
Dick, & Barb Cain
8681 posts in 2466 days
#2 posted 1107 days ago
The band saw would be the best, because of less wood waste.
GMman
#3 posted 1107 days ago
Thanks Don and Dick I will give it a try.
View richgreer's profile
richgreer
4474 posts in 1241 days
#4 posted 1107 days ago
You say “besides using a circular saw”. However, the absolute best way to do this is with track saw that is a type of circular saw.
It is hard to use a taper sled on a TS for something 8’ long. On the band saw the cut will only be as straight as your ability to follow the line.
With a track saw you would need some additional 2×4s beside the one you are cutting to support the track and saw. However, with the track in place you are going to get a virtually perfect cut.
When I say “track saw” I am thinking of what some may call a “plunge saw”. The best known is festool, but DeWalt and Makita both have their own versions available.
View 459fitter's profile
459fitter
30 posts in 1232 days
#5 posted 1107 days ago
GMman, You could attach a block of wood to leading end of your 2×4 which is one half the width of the 2×4 and then attach another 2×4 as a straight edge. Then run it through your table saw. Cut the block on the appropriate angle, should be about 8 degrees for an 8 foot 2×4. The long side of the block should be 1 3/4” long. Custom built taper sled!
-- Andy ---- Missoula, MT
View wchips's profile
wchips
314 posts in 1254 days
#6 posted 1106 days ago
Band saw it out staying outside the line approx 3/16’’ then run it over your jointer to clean up the saw marks. you will have to be careful when you get to the thin end
-- wchips
View Stargazer's profile
Stargazer
49 posts in 1106 days
#7 posted 1105 days ago
I agree with Rich, a circular saw and straight edge would be the best way to cut a taped 8’ 2×4. But you must first insure your 2×4 is straight or you’ll have to clamp/screw it down while pulling/holding it straight. This would go for any way you cut the taper.
You could also make the aforementioned sled with a 6” x 8’ x 3/4” piece of ply. Just screw the STRAIGHT 2x to the ply with drywall screws with the proper taper + 1 bladewidth overhanging one side. Then set the tablesaw fence to 6”, run the 2x/ ply through and you have the tapered piece you need.
Rick,
Pensacola, FL
richgreer
#8 posted 1105 days ago
From my recent experience I can say that a truly straight 2×4 is becoming quite rare. In fact, if I want a really straight 2×4 I buy a 2×12 and rip it. It seems like they put straighter material into the wider boards.
