Filling Cracks
Forum topic by DBordello posted 07-12-2016 05:33 PM 740 views 0 times favorited 11 replies Add to Favorites Watch
View DBordello's profile
DBordello
132 posts in 1248 days
07-12-2016 05:33 PM
Hello,
I am currently working with some walnut that I acquired locally that gave me the honor of warping, and cracking. i Have done the best I can, but I still have some pieces with some decent cracks in them:
I am not worried about the cracks structurally, but I wouldn’t mind cleaning them up a bit aesthetically. I plan to finish with BLO and Arm-R-Seal.
My first thought is to mix epoxy with saw dust and sand flat. Any tips for this procedure, such as the ratio? Other ideas?
11 replies so far
View FLBert's profile
FLBert
59 posts in 759 days
#1 posted 07-12-2016 05:42 PM
I would try either saw dust or maybe some dye mixed with the epoxy. The sawdust would need to be pretty fine stuff I would think. Not sure about ratios, but it looks like it won’t take much so maybe experiment with a small amount on a piece of scrap to see if the color looks right to you before putting it in the crack.
-- Bert, Lake City, FL
View MrUnix's profile
MrUnix
6757 posts in 2221 days
#2 posted 07-12-2016 06:00 PM
There is no one ‘ratio’ and just about anything can be mixed in with epoxy to give it color… sawdust, crushed up colored chalk, powdered and liquid painting pigments, metal shavings, stone dust or even stone chips, shredded fabric material (which is what West System #403 microfiber filler is), etc… Use your imagination. You just don’t want to make it too thick so it won’t flow into the crack. If you decide to use one of those syringe type epoxy things found at the BORG, keep in mind that most have quite a lot of filler in them already, unless you get the clear stuff.
View bigJohninvegas's profile
bigJohninvegas
456 posts in 1484 days
#3 posted 07-12-2016 08:56 PM
Well, you can embrace the checks and fill with something colorful. Or you can take a piece of scrap walnut, oil it with the BLO, and power sand the wet oil with a pad sander and 100grit. This will make a saw dust slurry that you can fill the checks with. You have to do it at the same time you oil the rest. When the oil cures, its as hard as the wood and won’t come out?
Test it on some scrap to see how it looks. Its not perfect, but the few time I’ve used it worked out well.
Also, I have alwys used danish oil, not pure BLO.
-- John
DBordello
#4 posted 07-12-2016 08:56 PM
John,
Excellent idea. I will give that shot.
bigJohninvegas
#5 posted 07-12-2016 09:57 PM
Also, make sure to clean your pad sander berfore the oil dries. It will clog the small dust collection holes.
I had to replace the pad on my makita sander the first time I did this. Live and learn. Lol.
-- John
runswithscissors
2762 posts in 2047 days
#6 posted 07-12-2016 10:02 PM
I prefer sanding dust in my epoxy. If you use walnut dust, the finish—whether oil or some kind of film—will darken considerably compared to the walnut. But I think it would look good. I do this frequently, sometimes for structural reasons, sometimes aesthetic.
The epoxy will run down into the crack like honey through holey hot buttered toast.. If the crack goes through, tape the backside so the epoxy doesn’t run out. Also, try to overfill the hole. It isn’t that the epoxy shrinks, but rather that it will settle into every nook and cranny, and can leave your repair sunken if you don’t top up. When cured (it doesn’t “dry”), sand flush.
View AandCstyle's profile
AandCstyle
3068 posts in 2279 days
#7 posted 07-12-2016 10:59 PM
DBordello, I mix epoxy with a drop of black TransTint dye and overfill the void as scissors mentioned. Here are a couple pix of a work in progress.
I apologize for the glare.
-- Art
View Kelly's profile
Kelly
2039 posts in 2966 days
#8 posted 07-13-2016 12:21 AM
I have several items I turned that cracked. I used a bit of plumber’s putty on the end and filled them with clear epoxy. When I show them to people, all they see is the item and not the 1/4” wide gap filled with clear epoxy.
View mahdee's profile
mahdee
3888 posts in 1789 days
#9 posted 07-13-2016 01:05 AM
You can also use bondo and use color pencils to connect the dark and light grains and make it virtually invisible.
-- earthartandfoods.com
View Snowbeast's profile
Snowbeast
82 posts in 1360 days
#10 posted 07-13-2016 11:05 AM
Overfill the crack with fine walnut sanding dust and then soak it with thin CA glue. When it’s cured, simply sand it flush with the surrounding surface.
This will look very similar to what Art showed but not quite as pronounced.
DBordello
#11 posted 07-13-2016 04:38 PM
Overfill the crack with fine walnut sanding dust and then soak it with thin CA glue. When it s cured, simply sand it flush with the surrounding surface.
- Snowbeast
I like this idea. I will give that a shot.
