Stone sharpening assistance
« back to Hand Tools forum
Forum topic by trevor7428 posted 07-12-2016 03:01 PM 1026 views 0 times favorited 26 replies Add to Favorites Watch
View trevor7428's profile
trevor7428
266 posts in 1108 days
07-12-2016 03:01 PM
New sharpener here looking for some assistance.
So I’ve been looking in the sharpening stones and at first I was really confusing, but I kind of have a little bit more understanding of how everything works. basically have the choice of water, oil and Diamond Stones. After doing my research, I believe I decided to use Diamond Stones.
I want to start to learn to sharpen my chisels and planes. I would love to find a set, that has all diamond stones I would need with one purchase. So far I found This
This has good reviews on amazon. Just worried about only being 2in wide, when working with plane blades.
Does anyone know of a better kit out there?
-- Thank You Trevor OBrion
26 replies so far
View BurlyBob's profile
BurlyBob
5918 posts in 2413 days
#1 posted 07-12-2016 04:31 PM
That’s a real nice looking set. I’ve been very satisfied with granite countertop scraps. wet/dry sandpaper and a Veritas MkII jig. I’m scheduling a whole week soon just for all the plane irons I have begging for attention.
View TheFridge's profile
TheFridge
10344 posts in 1633 days
#2 posted 07-12-2016 04:38 PM
I have a 6×2 and it is doable for most irons. 8×3 is a big step up.
Personally, the edge left by an extra fine diamond stone isn’t good enough for me.
View HokieKen's profile
HokieKen
6296 posts in 1286 days
#3 posted 07-12-2016 04:42 PM
Personally, I have 4 stones – Coarse, Medium, Fine, Extra Fine. Unless I’m dressing a new tool or re-shaping a bevel, I never use coarse and rarely use medium. My recommendation would be the 8” continuous diamond stones in Fine and Extra fine. Use sandpaper on a flat surface when you need something coarser. Use a strop with some compound when you need something finer. Just my $.02, YMMV of course.
-- Kenny, SW VA, Go Hokies!!!
HokieKen
#4 posted 07-12-2016 04:45 PM
Personally, the edge left by an extra fine diamond stone isn t good enough for me.
- TheFridge
I usually follow x-fine diamond with hard black Arkansas and/or green compound on leather strop FWIW.
View KelleyCrafts's profile (online now)
KelleyCrafts
3188 posts in 887 days
#5 posted 07-12-2016 05:09 PM
- TheFridge
Can you comment more on this. I was thinking of doing the course, fine, and extra fine because I am frustrated with the mess and prep time for my water stones.
https://www.amazon.com/gp/product/B0009H5C5M/ref=ox_sc_sfl_title_16?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
I saw the set the OP posted and thought about that but some of my plane blades are much wider than the 2” so I don’t think that’s the best option. For 50-75% more money you get 100% more sharpening surface. Haven’t pulled the trigger yet because my water stones do fine, just a hassle.
-- Dave - http://kelleycrafts.com/ - pen blanks - knife scales - turning tools
KelleyCrafts
#6 posted 07-12-2016 05:11 PM
Personally, I have 4 stones – Coarse, Medium, Fine, Extra Fine. Unless I m dressing a new tool or re-shaping a bevel, I never use coarse and rarely use medium. My recommendation would be the 8” continuous diamond stones in Fine and Extra fine. Use sandpaper on a flat surface when you need something coarser. Use a strop with some compound when you need something finer. Just my $.02, YMMV of course.
- HokieKen
Love this advice!! Makes so much sense! I can pull out water stones and paper to do new stuff but my touch ups just on the two diamond blocks and a strop (which I already use). Love this….doing this. Still curious why the fridge doesn’t think the extra fine is good enough.
KelleyCrafts
#7 posted 07-12-2016 05:25 PM
Sorry Trevor for hi-jacking a bit there. I definitely would go your route but I would get a larger sharpening surface. Just my thoughts.
View Aj2's profile
Aj2
1726 posts in 1945 days
#8 posted 07-12-2016 05:38 PM
I have used diamond stone for sharpening and I have a pile of worn out plastic Dmts to prove it.
They start out great.But the sharpness of the grit is easy to fracture and dull.
I would recommend some water stones with your new setup.If you want to start hand planing some of your projects a fine grit water stone is a must.
But just like everyone else I still buy those cheap Dmts.Alwalys looking for that Magic bullit.
Aj
-- Aj
View jgt1942's profile
jgt1942
203 posts in 2036 days
#9 posted 07-12-2016 06:00 PM
IMHO the DMT sharpening system is the way to go. If you search DMT on Amazon you will also find an 8” and 10” offerings. I currently have a set of Shapton ceramic stones all the way up to 8000 grit. They are great stones but I think if I were to replace them I’d go with the DMT stones. However I do question this based on Aj2 comments.
I also have the Jet slow-speed wet-wheel grinder. Looking back possibly the DMT stones would be good enough to even replace it.
-- JohnT
trevor7428
#10 posted 07-12-2016 06:29 PM
Thanks everyone for the ideas. Like I said, I’m new into sharpening. Well technically haven’t even bought they stones yet lol, but stupid question. When is a strop and compound used? Is it only for diamond or all types of sharpening stones?
I guess I need to find a good YouTube video that explains it.
jgt1942
#11 posted 07-12-2016 06:37 PM
The strop is used as the final sharpening step. If done correctly it will give you a razor sharp edge. However you need to learn how to get the tool properly sharpened before using the strop. Using a strop on a poorly sharpened tool will not do anything for you but polish the tool.
-- JohnT
View Bill White's profile
Bill White
5072 posts in 4108 days
#12 posted 07-12-2016 07:36 PM
Check out David Weaver on the tube. This guy is the most practical professor about planes and chisels on the net, and he WILL respond to questions.
Bill
-- bill@magraphics.us
View Aj2's profile
Aj2
#13 posted 07-12-2016 07:50 PM
IMHO the DMT sharpening system is the way to go. If you search DMT on Amazon you will also find an 8” and 10” offerings. I currently have a set of Shapton ceramic stones all the way up to 8000 grit. They are great stones but I think if I were to replace them I d go with the DMT stones. However I do question this based on Aj2 comments.
- jgt1942
I think if you replace your Shaptons with Dmts you will be going backwards.
I also hollow grind on a tormek when I have no patience I use a my grinder.But I try to stay away from the grinder because it’s like watching a pencil disappear in a electric pencil sharpener.I have more time than money right now.
Here’s a pic of my sharpening station.I piled up some old worn out Dmts.
That’s also a well worn Drlp not cheap.Thank god it still has one good side.
- jgt1942
-- Aj
View bbasiaga's profile
bbasiaga
1240 posts in 2142 days
#14 posted 07-12-2016 08:52 PM
FWIW, i am a new sharpener myself and I started out on a 1k/6k waterstone for my chisels. I eventually added a coarse diamond stone to flatten it with. I added a wider 4k/8k waterstone when I got a few hand planes. And later a fine diamond stone.
I’m not really sure what works best. The prevailing wisdom is that planes need to go to 6 or 8k and be stropped. And diamond stones don’t get that fine. I do kinda of feel waterstone work faster, but no real proof of that.
One thing I learned at a woodworking class that has made waterstone easier for me: just store them in a bucket of water. They are always ready. Pull it oit, flatten quickly on the diamond stone, sharpen, back in the bucket. Done. No wait rime, minimal mess.
I have taken to stripping after too. Makes a big difference on the paper test. Not real sure if it makes a difference on the wood.
Brian
View bondogaposis's profile
bondogaposis
4993 posts in 2499 days
#15 posted 07-12-2016 09:08 PM
I’m with Fridge, the extra fine diamond stones are still too coarse for final honing. I am currently using Norton water stone 8000 grit for a much finer edge.
-- Bondo Gaposis
