Record SC4 Chuck question
« back to Woodturning forum
Forum topic by marcsitkin posted 07-11-2016 04:31 PM 585 views 0 times favorited 4 replies Add to Favorites Watch
View marcsitkin's profile
marcsitkin
28 posts in 901 days
07-11-2016 04:31 PM
Hi-
I just received a new Record SC4 chuck, which I’ve assembled and mounted to my Rikon 70-220 VSR Lathe. I started up at a medium speed and immediately noticed the whole lath was vibrating. No wood was mounted in the chuck. I checked the run out at the circumference of the chuck, and it’s got about .005” of run out.
Is it normal for a chuck to cause a lathe to vibrate? The lathe is as smooth as can be with the spur center mounted. The lathe is securely bolted to a very heavy stand.
-- Thanks, Marc Sitkin, Harwich, MA
View TheDane's profile
TheDane
5524 posts in 3807 days
#1 posted 07-11-2016 04:47 PM
No. Just a WAG, but I would say you got a defective chuck.
View Wildwood's profile
Wildwood
2423 posts in 2279 days
#2 posted 07-11-2016 07:42 PM
Would also check spindle run-out without chuck installed. If that’s okay, would remove threaded insert and reinstall making sure torched down evenly.
If still have a problem would ask for an exchange or refund of either lathe or chuck!
-- Bill
View JoeinGa's profile
JoeinGa
7739 posts in 2151 days
#3 posted 07-11-2016 08:40 PM
Also are the jaws clamped shut? If they’re partially open, might be a bit of movement causing unbalance
marcsitkin
#4 posted 07-12-2016 04:02 PM
Bill-
Runout on the spindle with no chuck was about 1/1000”
Removed and reinstalled threaded insert, made no difference.
Joe- Jaws clamped shut, same vibration.
Vibration seems to be at around 1000 rpm, diminishes above and below that speed. Seems like it may be a harmonic situation.
I plan on getting a member of the turning club over to further investigate.
Thanks to all for your feedback.
