question about a possible tool purchase Ridgid RS1000 RAS
Forum topic by , posted 05-06-2010 06:14 PM 2880 views 0 times favorited 3 replies Add to Favorites Watch
View ,'s profile
2387 posts in 3540 days
05-06-2010 06:14 PM
CL has a RS1000 for 250.00 right now. I am tempted. I am in the market for adding a RAS or maybe two RAS to our collection. We currently run a Ridgid TS3660 and TS4511. My idea would be to rip my plywood on the TS and then cross cut my cabinet sides on the RAS using a stop block set up. That would add consistency, efficiency and speed to the operation. The second RAS I want to add would be set up with a Dado blade as we run a cross cut Dado on the top and bottom of all of our cabinet sides. I looked and the RS1000 only has a 13” cross cut. I would run a dado on this RAS and would set up a stop block on the left and right side of the dado blade, this way on a cabinet side that is cut 23 1/4” wide I could cut 1/2 of the dado on the top, move the cabinet side down to the other stop, cut 1/2 dado on the bottom, turn the piece 180 degrees and finish the last 1/2 of the dado on top and bottom. Any suggestions or advice. I do think 2 RAS added to our shop will help our overall production of the cabinets. Right now I dado using a jig and top mounted bearing on a router straight bit. This is a slow process but leaves a clean cut.
3 replies so far
View rhett's profile
rhett
742 posts in 3661 days
#1 posted 05-06-2010 11:42 PM
Get a slider for your TS and a panel router for your dado’s. RAS take up tons of room and leave lots of room for error.
-- Doubt kills more dreams than failure.
View ,'s profile
#2 posted 05-07-2010 02:52 AM
Rhett, I actually never thought about those two ideas. Can you give me some recommendations as to a slider for a TS and also a good panel router. I have 9 routers because I love routers but I don’t have any panel router system. Any suggestions?
rhett
#3 posted 05-07-2010 07:50 PM
HER-SAF makes the best. You can pick up a used one for around $1500. Sounds like alot, but new they are about 10x that. You can also make one with a kit. With two interchangable plates, one for a circular saw and one for a router, you can handle plywood allday.
