piano coat rack?
Forum topic by scorelesssteve posted 07-10-2016 10:32 PM 3512 views 1 time favorited 14 replies Add to Favorites Watch
View scorelesssteve's profile
scorelesssteve
16 posts in 1005 days
07-10-2016 10:32 PM
does anyone have plans they can share for this?
14 replies so far
117091 posts in 3574 days
#1 posted 07-10-2016 11:11 PM
No photo no link?
scorelesssteve
#2 posted 07-11-2016 01:04 AM
runswithscissors
2751 posts in 2022 days
#3 posted 07-11-2016 06:02 AM
So each/all of those pegs can swivel out? Really interesting design. I may steal this. Probably need to be spring loaded somehow to close them up when not needed.
Looks quite simple. Why would you need plans?
View Redoak49's profile
Redoak49
3242 posts in 1986 days
#4 posted 07-11-2016 10:42 AM
I want plans also. Would love to know how they did the swing out pegs.
This was so easy…try Google. I just did and easily found a bunch of links for “piano hinge coat rack plans”.
One was a good video.
View dhazelton's profile
dhazelton
2767 posts in 2294 days
#5 posted 07-11-2016 11:24 AM
Every other strip runs full height, steel rod or wooden dowel runs horizontally the full width. I’d cut the strips, drill all the holes on a drill press with some sort of stop so everything aligns and assemble it. A full strip on each side hides the rod or dowel end. It doesn’t look difficult, just looks like it will take some thought.
It looks cool at first but to me it doesn’t seem like a very efficient storage idea.
View rustynails's profile
rustynails
747 posts in 2526 days
#6 posted 07-11-2016 12:17 PM
I love the simplicity and functionality of this design
View JoeinGa's profile
JoeinGa
7736 posts in 2004 days
#7 posted 07-11-2016 12:54 PM
I was thinking more along the lines that you had an old upright piano and were going to make a coat rack from it. And why not? People make desks and bars from them, so why not a coat rack?
scorelesssteve
#8 posted 07-11-2016 01:32 PM
i tried google but still not seeing any plans could you post a link ?
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3710 days
#9 posted 07-12-2016 04:36 AM
You could use magnets at the tops or sides to hold them up when not in use.
scorelesssteve
#10 posted 07-12-2016 06:49 PM
no one has any ideas to get plans ?
View MrUnix's profile
MrUnix
6709 posts in 2196 days
#11 posted 07-12-2016 06:51 PM
I don’t really see a need for plans, other than some rough measurements on the back of a napkin. It’s all just the same dimension rectangular stock, some longer than others, and all secured with glue and some all-thread (or whatever you want to use to allow the pieces to pivot). Did you watch the video of one being made?
View mahdee's profile
mahdee
3883 posts in 1765 days
#12 posted 07-12-2016 06:58 PM
Here is a video
-- earthartandfoods.com
View CaptainSkully's profile
CaptainSkully
1598 posts in 3556 days
#13 posted 07-16-2016 05:52 PM
This is a little more complicated that it looks at first. The full length up rights (at least some of them) are deeper than the flip out pegs. This give the bottom of the peg clearance to swing out until it hits the wall.
-- You can't control the wind, but you can trim your sails
runswithscissors
#14 posted 07-16-2016 06:54 PM
Since that might eventually damage the wall, you could put a plywood back on it. Would prevent racking, too, though I doubt if that would be necessary.
