Mighty miter fence for table saw
Forum topic by Slavisa Nesic posted 07-10-2016 07:18 PM 528 views 0 times favorited 0 replies Add to Favorites Watch
View Slavisa Nesic's profile
Slavisa Nesic
11 posts in 1361 days
07-10-2016 07:18 PM
Topic tags/keywords: miter fence table saw do it yourself
Cutting short laths on a small table saw is achieved simply and with no problems. Of course the miter fence is used for that purposes. But what about crosscutting long board, or heavy board? In that case the tiny factory made miter fence is not appropriate. What is even worse is you risk the strong kickback of fast rotating saw blade.
Some people assume and even use a sled as the solution for crosscutting long lumber. Not a safe solution!
I made a modified miter fence of wood and steel that will serve the crosscutting much safer, more compact and more comfortable then any sled or factory miter fence, at least when small amateur table saws are to be used.
For detailed construction details you can refer to my site at
-- This land is not mine, not yours, this land is given to all of us, to come, to meet, and leave with no return.
0 replies so far
