Trouble finishing Scott Morrison rocking chair (Can't get correct angle on seat)
Forum topic by yellowtruck75 posted 05-06-2010 02:46 AM 3548 views 0 times favorited 3 replies Add to Favorites Watch
View yellowtruck75's profile
yellowtruck75
469 posts in 3066 days
05-06-2010 02:46 AM
I am having a bit of trouble finishing my Scott Morrison “simple rocking” chair. I have finished everything but mounting the rockers correctly. I have drilled the chair legs and rockers and have mounted them with pegs. The trouble I am having is that when the chair is sat in you tend to lean forward a bit. Due to the angle of the chair it is hard to rock all the way back and be comfortable. I was thinking of grinding a half inch off the back legs to get the correct angle on the seat. Will this work? What else could I try?
Thanks
3 replies so far
View Tony_S's profile (online now)
Tony_S
868 posts in 3082 days
#1 posted 05-06-2010 04:58 AM
Scott is a member here…why not shoot him a message, I’m sure he can give you some pretty good advice.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View Nomad62's profile
Nomad62
726 posts in 2957 days
#2 posted 05-06-2010 11:40 PM
If it were me and I tried that, it would simply set my body back a little, but still tip me too far forward to be comfortable. But that’s my luck. So I would tend to recommend using a calculation on a ‘center of weight” that your body creates when sitting in the chair, then finding a way to place that center more towards the rear of the chair.
View DanaM's profile
DanaM
1 post in 1640 days
#3 posted 12-12-2013 11:26 AM
Have had the same issue arise with my Haig style chair, just it was noticed after it was all put together and glued. Do you know if it is possible to increase weight in the back of the rockers?
