Forum topic by hoplandhophead | posted 05-05-2010 06:01 PM | 1040 views | 0 times favorited | 3 replies | ![]() |
I have wide redwood boards formerly used as wainscot in a turn of the century home. My plan is to use four boards to “frame” a window. The wall has a 6’ x 4’6” window in the center. The bottom board would run horizontally the full width of the wall (9’) and would be 24” (that’s right – 24”!!) wide. On each side of the window would be a vertical board 18” wide, resting on top of the bottom board and running to the top of the space (5’6”). Finally, a 12” board would be on top of the window and between the two vertical boards (4’6”). I would like to butt the boards best i can and call it good. alternatively, i would leave a gap between the joints and cover the joints with a batten. I fear that if i butt the seams seasonal movement will buckle or otherwise harm the installation. the boards are 7/8”. thanks for any input. jeff -- jaypee |
