Thien baffle build question...
Forum topic by Jim Dawson posted 07-09-2016 01:05 PM 1010 views 0 times favorited 13 replies Add to Favorites Watch
View Jim Dawson's profile
Jim Dawson
103 posts in 703 days
07-09-2016 01:05 PM
I’m going to attempt to build a Thien baffle but I’ve already run into a question – where can I buy the Lexan and what thickness do I buy? I’ve seen many thicknesses online and really expensive large sheets. Do any of the big box stores carry something suitable?
Thanks,
Jim
13 replies so far
View HorizontalMike's profile
HorizontalMike
7727 posts in 2785 days
#1 posted 07-09-2016 01:28 PM
FWIW, I built my trashcan top Thien using 3/4”plywood, 1/4” hard board, some all-thread, and a couple of 90* 4” couplings.
http://www.horizontalheavens.com/Thien%20Dust%20Separator.htm
If it didn’t work so well, and it does, I would have replaced it with an artsy fartsy unit… ;-)
View Holbs's profile
Holbs
1766 posts in 1900 days
#2 posted 07-09-2016 02:51 PM
I bought my Lexan locally at a plastic shop, the kind of place that sells plastic for business signs and such.
http://www.silverstateplastics.biz/
went 1/16” lexan x 16” high x 60” length for $20 or so.
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
View johnstoneb's profile
johnstoneb
2691 posts in 2043 days
#3 posted 07-09-2016 03:27 PM
I just used the trashcan lid separator Woodcraft sell added an inlet elbow to direct the flow toward the outside of the can and hung a baffle below the elbow on all-thread. Works great.
Mine looks a lot like Horizontal Mike’s with out the cutout on the elbow. You definitely don’t need all that artsy fartsy stuff.
-- Bruce, Boise, ID
View Rentvent's profile
Rentvent
151 posts in 720 days
#4 posted 07-09-2016 07:54 PM
I made one out of a cardboard drum:
Here’s before I added in the bottom circle with the slot:
the blue ring is the cut-out lid of the plastic drum that it sits on
The other half of the cardboard drum in the background is to hold the donaldson\wynn filter.
The black bellmouth fitting on the outlet pipe in the center is a subwoofer port
View joey502's profile
joey502
519 posts in 1389 days
#5 posted 07-09-2016 08:51 PM
The bix stores around me sell polycarbonate . Most mom and pop hardware stores have it on hand to cut the size you need.
The plastic will cut nicely on a bandsaw if you find an oversized piece.
Lexan is a brand name of polycarbonate. If you search or ask for polycarbonate instead of the name brand you may have more luck sourcing what you need.
View JIMMIEM's profile
JIMMIEM
42 posts in 712 days
#6 posted 07-09-2016 08:56 PM
Trash can and 1/2” plywood for the baffle. Threaded rods. Plastic parts from Grizzly.
View Woodchuck2010's profile
Woodchuck2010
704 posts in 729 days
#7 posted 07-10-2016 01:13 AM
If it didn t work so well, and it does, I would have replaced it with an artsy fartsy unit… ;-)
- HorizontalMike
Really like your shop!
-- Chuck, Michigan,
Jim Dawson
#8 posted 07-10-2016 01:46 AM
Thanks for all the tips. I’ll start on it soon.
View curliejones's profile
curliejones
177 posts in 2137 days
#9 posted 07-26-2016 11:49 AM
I used acrylic sheet from an old light fixture. I had plenty on hand and it works just fine. It is opaque and has the advantage of letting you see (somewhat) that cyclonic effect is there without mesmerizing you for hours on end and no work gets done LOL.!
http://lumberjocks.com/projects/252418
-- Like Guy Clark sez - "Sometimes I use my head, Sometimes I get a bigger hammer"
View Notw's profile
Notw
605 posts in 1624 days
#10 posted 07-26-2016 03:09 PM
I used metal flashing for mine, works great
View Mark's profile
Mark
868 posts in 1845 days
#11 posted 07-26-2016 03:54 PM
- HorizontalMike….Any thoughts how your top hat might work with a DW735? Sweeping’ the floor all the time is making’ me tired. Thanks.
PS not trying to hack Jim’s thread.
-- Mark
View toolie's profile
toolie
2099 posts in 2499 days
#12 posted 07-27-2016 12:44 PM
Put the baffle in the dust collector and save space( no separator) while limiting the dust in the filter.
View WoodES's profile
WoodES
87 posts in 1562 days
#13 posted 07-28-2016 03:54 AM
I found the best sheets at Lowes. I forget the brand but was easy to flex into the circular shape. The sheet I found in the local plastic distributers scrap pile kept breaking. I only used a thickness of about 1/8” and it has worked very well.
Good luck.
