| Forum topic by AKWoody | posted 1109 days ago | 586 views | 0 times favorited | 5 replies | ![]() |
1109 days ago |
So I glued up some cherry strips to the edge of my cherry ply, of course they needed a bit of trimming and that is where I got in trouble. I used a block plane and managed to get right through the veneer. What is the best tool for work like this. Thanks in advance. |
5 replies so far
#1 posted 1109 days ago |
Use a flush trimming bit in a router table with a fence tall enought to keep the shelf vertical. With the right setup you don’t really even need the bearing. The fence would be about 4” tall with a rabbett at the bottom to allow for the overhang of your applied edge a little taller than the thickness of the edge. The edge’s face goes down on the table with the shelf running against the fence. The fence is set so it leaves a thousandth or so of the edging proud of the veneer surface. You are kind of using the router as a small jointer. Then sand it lightly. Scrapers work too. I haven’t had to contend with today’s plywood much, yet. I bet the veneers are quite a bit thinner than when I stopped building cabinets. (12 years ago) The imported plywood these days (and even then) has very thin veneer and does not take much to sand through. I tried to buy the domestic stuff with 1/28 ” veneer. We used to use a belt sander with a worn belt without much trouble. Still had to be careful. -- Michael Murphy, Woodland, CA. |
#2 posted 1109 days ago |
I use a ROS moving it quickly along the edge at 20 degrees give or take with hardly any pressure -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#3 posted 1109 days ago |
I generally use a flush trim bit as well. I have also used a ros but, as Jim says, you have to be careful not to sand through the veneer. -- Challenges are what make life interesting; overcoming them is what makes life meaningful- Joshua Marine |
#4 posted 1109 days ago |
The veneer on the plywood is surprisingly thin considered what I paid for the stuff. I never even thought to use my router table, I will next time for sure! I managed to finish the job with a ROS, being extremely careful. The place I sanded through is a great place to put the brass gift tag I was planning on attaching:) Thanks. |
#5 posted 1109 days ago |
I agree with Jim on the ROS. For years I did that with a belt sander, although I would not recommend doing it that way. Takes a very light touch with the sander. And yes, thin veneer has become quite a problem for all of us. A flush trim bit is also a good method. -- She thought I hung the moon--now she just thinks I did it wrong |
| Forum | Topics |
Woodworking Skill Share
8782 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3542 |
15752 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
