Liquid Inlay question??
Forum topic by mdbohica posted 05-05-2010 03:26 AM 7553 views 2 times favorited 12 replies Add to Favorites Watch
View mdbohica's profile
mdbohica
26 posts in 3281 days
05-05-2010 03:26 AM
I am making a bookstand for a friend and I am going to carve out a design on the front of it. When I remove the material, I want to pour in some kind of hardening liquid that I can dye black or red to fill the channels I carve out. I was thinking of some kind of epoxy but it would need to flow almost like water to be sure that there will be no bubbles when I pour.
Any Suggestions?
Thanks in advance.
12 replies so far
View Chelios's profile
Chelios
568 posts in 3300 days
#1 posted 05-05-2010 03:33 AM
Could you use a bar top finish? Check out envirotex lite – Pour on finish
View D1st's profile
D1st
291 posts in 3274 days
#2 posted 05-05-2010 03:44 AM
You could use a non sanded grout and then a clear epoxy over it.
-- http://www.furstwoodworks.com/
View Sean's profile
Sean
156 posts in 3849 days
#3 posted 05-05-2010 03:44 AM
I’ve seen several articles on people doing this, and several projects in mags…unfortunately i can’t refer you to any of them…but they were all done with epoxy, and there was no mention of problems with bubbles, so it didnt appear that it was a problem.
-- "Democracy is by far the worst system of government. Except all the others that have been tried." ~ Winston Churchill
View j_olsen's profile
j_olsen
155 posts in 3405 days
#4 posted 05-05-2010 03:49 AM
here is something that was on steve goode’s scrollsaw blog that might hit what you’re looking for
http://www.inlacebook.com/index.html
-- Jeff - Bell Buckle, TN
13641 posts in 3575 days
#5 posted 05-05-2010 03:55 AM
i pour all the time ,
the secret to the bubbles ,
you have a spritzer bottle ,
(like a windex bottle ) , and watch it ,
not lazily but sit by it and spray for about an hour
i use lacquer thinner , i first coat the cut out with sealer ,
( laquer , varathane ,deft , whatever ) , so that the wood doesn’t suck the tint out of it and run in .
i use regular hobby paint , from wal-mart , lot’s of colors .
i have also read here that a hair dryer , as the bubbles come up ,
( they do it as they feel like ) will heat them and they burst .
but if you just let the drier sit , (thinking about speeding thing up ) ,
it heats everything up ,
it will just make things kick faster , trapping any bubbles in your inlay ,
then when you sand , they are like little hollows in the mix . if you get distracted talking on the phone , forget it !
here is what happens without sealing the wood first ,
( this isn’t the finish , just for the in-size , and surrounding surface )
i just spray the whole surface , and get it in the in-size well .
the epoxy wants to be proud of the surface .
it all gets sanded later , including the sealer .
View miserybob's profile
miserybob
88 posts in 3278 days
#6 posted 05-05-2010 04:03 AM
I’ve used epoxy as an inlay on many occasions (the inlace product is pretty fun, but you can use any epoxy) – you can color it in many ways, I often use Mixol. It is difficult to avoid bubbles, though. I’ve had people suggest using a hair dryer to heat the epoxy after filling, putting the wood in the oven for a few minutes, etc. I find the best you can do is make the carving extra deep and overfill a little… that way you can sand or plane through any bubbles that appeared in the surface.
Consider, too, the type of wood, the intended stain, and the color of epoxy you’ll be using. Epoxy tends to bleed into the pores of the wood (some people suggest a wash coat of shellac on the surrounding area), which can ruin the effect on light woods.
Get some epoxy and experiment before attempting anything on your nice, carved piece!
[edit] Ha! David either types faster than me, or had a head start! Good advice, David. Have you found any issue with adhesion of the inlay when you coat first with lacquer? I’ve been meaning to try that, but was afraid that it would interfere with the epoxy. Thanks!
[edit again] Here are a couple of things I’ve done with epoxy…
Lantern
Seahorse
j_olsen
#7 posted 05-05-2010 04:06 AM
here’s steves demo of the product
http://scrollsawworkshop.blogspot.com/2009/12/new-key-chain-patterns-and-video.html
#8 posted 05-05-2010 04:40 AM
bob ,
if anything ,
i found that you need to SEAL the wood well ,
any sealer dries so thin ,
that it really needs to build some .
the channel is rough enough to hold the epoxy well .
View Sean's profile
Sean
#9 posted 05-05-2010 04:41 AM
miserybob, that freakin rocks.
16281 posts in 4452 days
#10 posted 05-05-2010 04:56 AM
Good old fiberglass resin from the home center works great as well.
View 3DWoodworkingSupply's profile
3DWoodworkingSupply
26 posts in 3279 days
#11 posted 05-05-2010 07:15 AM
View davyj's profile
davyj
38 posts in 3084 days
#12 posted 05-25-2012 03:07 PM
don’t know if you will ever see this. looks like a very old post. I have and used Inlace brand. tis one of the most expensive, but very good stuff It does NOT shrink/ the regular fiber glas resin DOES. form my stand point/experiance, the Envirotex and brand Pour On works really good and seems to accept most any craft paint for coloring. it doesn’t take much pending on how much resin/hardner you need. best part is the 50/50 mix ratio where as Inlace one counts drops per size of amount of resin used. I have also used craft paint to line the inside of the scroll sawed hole to keep bleed outa the grain. IF a ciontrasting color is used for this and a liberal amount it will also serve to outline. Let it dry good before pouring in the mix. I have been doing diff inlays in the bottom of segmented bowls. Do scroll saw work and inlay in a diisk THEN build the bowl from there.
-- retired GM/Delphi , Retired USN/USAFR
