HELP. I put boiled linseed oil on a cherry tabletop and left it in the sun to darken a bit...
Forum topic by bayouwood posted 07-08-2016 12:17 PM 1577 views 0 times favorited 13 replies Add to Favorites Watch
View bayouwood's profile
bayouwood
26 posts in 783 days
07-08-2016 12:17 PM
and i forgot about it and there was some light rain overnight. It has a slight cup to it. What can i do? I dried it off and brought it inside. should i clamp it flat with cauls while it dries? should i point a fan at it? should i point an air conditioner vent at it? Should i just leave it alone?
Maybe the BLO helped it from absorbing too much water…
any advice is appreciated
13 replies so far
bayouwood
#1 posted 07-08-2016 12:32 PM
for the record, a few weeks ago i left the glued up panel in the garage for a few days (this was before the BLO) It cupped in the outside humidity but flattened out after a day or so inside. Not sure if the same would happen here if it has some surface moisture from the rainhttp://lumberjocks.com/topics/169610#...
View punkin611's profile
punkin611
49 posts in 692 days
#2 posted 07-08-2016 12:55 PM
You might try putting it in the mid day sun cupped side down and watch it closely. Take it out when it’s level. You might have to do that a few times just remember to put it in sun cupped side down. Good luck.
bayouwood
#3 posted 07-08-2016 01:16 PM
i cant leave it outside to flatten. nightstand panel (quite small) and the humidity alone is enough to keep it cupped regardless of gravity. It is glued up with rings in opposite directions (3 boards) but it still wants to go that way. i have a granite countertop completely flat I think I will clamp it to with fans blowing
bayouwood
#4 posted 07-08-2016 01:41 PM
i put it cup side down (this was also the side that was down in the rain, so i dont think it got wet) and clamped it with cauls on newspaper to get any residual moisure… crossing fingers.
i think halfway through the day I will rotate the panel and clamp it across the boards
View josephf's profile
josephf
173 posts in 1967 days
#5 posted 07-08-2016 01:59 PM
wow , this sounds promising .let us know if it works . i have tried to ‘over bend’ in order to take out the bow in a few drs . .if what your doing doesn’t work you might shove a wedge[scrap of wood] under the middle and clamp till it bows some .
something sounds wrong though – did it cup up .if so the bottom absorbed the moisture not the top . fans would need to be blowing on the longer convex surface .
josephf
#6 posted 07-08-2016 02:03 PM
maybe you could span them across ,between two surfaces and set a weight in the middle. cup is up ,weight gentle helps to lower it .the fans blowing could help move moisture away .
bayouwood
#7 posted 07-08-2016 02:04 PM
it cupped down. it was sitting on a small footstool in the yard, so the bottom wasnt in sitting water and probably didnt get anything. The side you see pictured is the side that was facing the sun, and is the longer convex surface. no fans right now, just sitting on the air conditioning. i figure if i let it dry slowly my results will be better.
View gargey's profile
gargey
870 posts in 646 days
#8 posted 07-08-2016 02:12 PM
I’d let it dry out indoors without and kind of pressure applied and see what it looks like then before trying to do any forcing or fixing.
View gator9t9's profile
gator9t9
330 posts in 3575 days
#9 posted 08-09-2016 07:50 PM
Question…..
What good does the sun ever do to any piece of wood, with the exception of
Helping wood or trees to grow.
Sure there are some woods that are very survivable in the sun…TEAK is one. Western red Cedar is another
But I think finishing in the sun is not a good practice
I say let your piece dry out of the sun and never again in the sun.
You may have to refinish and start over
Mike
Gator9t9
-- Mike in Bonney Lake " If you are real real real good your whole life, You 'll be buried in a curly maple coffin when you die."
View BulldogLouisiana's profile
BulldogLouisiana
325 posts in 1010 days
#10 posted 08-09-2016 08:00 PM
Question…..
Mike
Gator9t9
- gator9t9
Well, sunlight is useful to darken cherry faster. I know some people that have done it, but not after finishing I don’t think.
-- There are 10 types of people in the world. Those who understand binary and those who don't.
bayouwood
#11 posted 08-09-2016 08:16 PM
Yep, popular woodworking found the best cherry darkening was from applying BLO then putting in the sun. http://www.popularwoodworking.com/techniques/adding_age_to_cherry
If anyone cares, i unclamped the piece and just let it sit inside in the air conditioning. The bow is only about 1mm now, and it will flatten when I attach the skirt with no problem
View jwmalone's profile
jwmalone
769 posts in 573 days
#12 posted 08-09-2016 09:12 PM
Glad it worked.
-- "Boy you could get more work done it you quit flapping your pie hole" Grandpa
View Rick_M's profile
Rick_M
10812 posts in 2250 days
#13 posted 08-10-2016 05:16 AM
- bayouwood
It’s a tip that been around a long time but people keep forgetting it. BLO alone will mildly accelerate oxidation but the sun supercharges the reaction.
-- http://thewoodknack.blogspot.com/
