How to blacken a zinc bolt
Forum topic by Brandon Wittwer posted 05-04-2010 02:12 AM 22861 views 0 times favorited 11 replies Add to Favorites Watch
View Brandon Wittwer's profile
Brandon Wittwer
6 posts in 2822 days
05-04-2010 02:12 AM
Topic tags/keywords: black oxide blackening blackened bolt carriage
I couldn’t find any black oxide bolts at my Big Orange Box store, and I was late for dinner, so I picked up zinc carriage bolts instead. Now I need to find a way to blacken them. I hoped it would be as easy as taking a torch to them, but it only lost the sheen of the zinc, but was deffinately still silver in color.
Any suggestions?
I know officially i need caustic soda to make black oxide…. i cant say I have any laying around…. so anyone know how to make / come up with it / another way to make my bolts black?
Thanks so much community. I’ll post pics of the bench when its done.
-- Ridgid 4511 Granite top table saw. A one car garage stocked full of craigslist tool purchases. And I have no idea what I can make!
11 replies so far
View Dark_Lightning's profile
Dark_Lightning
3032 posts in 2983 days
#1 posted 05-04-2010 02:24 AM
Do not heat zinc in a closed space with a torch. The fumes can be lethal. Be careful in open air for that matter. You probably just vaporized the zinc off, leaving the raw steel below exposed. No joke.
If you look again, I’m sure I have seen black carriage bolts, but they were probably lead-filled black paint from China. Don’t heat those, either, if there is lead in the paint.
-- Random Orbital Nailer
View MedicKen's profile
MedicKen
1610 posts in 3336 days
#2 posted 05-04-2010 02:30 AM
Vinegar and steel wool in a bottle. Mix the 2 together and put the bols in the solution and let it set. Be patient
Brandon Wittwer
#3 posted 05-04-2010 02:31 AM
Its probably what happened when i torched it… Poof after about 20 seconds of heat, the zinc vaporized. I’ve played with pennies doing that too… fun stuff making hollow pennies….
So now that I have bare steel, i still need it black…. and a sharpie isnt my favorite solution.
Brandon Wittwer
#4 posted 05-04-2010 02:41 AM
Thanks medicKen. i’ll give it a shot right now… how long do you think it will take for that to work? and Should I start by removing the zinc – ala Torch?
MedicKen
#5 posted 05-04-2010 02:55 AM
I will most likely take a few days. You can also use the same solution to ebonize wood
Brandon Wittwer
#6 posted 05-04-2010 03:34 AM
thats the first time I’ve ever heard the word ebonize, so I looked it up. What a great piece of education. I think I’ll have fun with that. Thanks
View Knothead62's profile
Knothead62
2581 posts in 2835 days
#7 posted 05-04-2010 02:45 PM
Go outside, heat it a bit and drop it in a metal can with motor oil. I watched a gunsmith do this with gun parts. Came out with a nice finish.
Brandon Wittwer
#8 posted 05-08-2010 08:00 AM
well the vinegar and steel wool did the trick. It put a nice layer of rust all over the threads that were above the vinegar’s surface and set a decent darkening to the bolt under the surface. I did fire off the zinc first before trying to apply the ebonizing solution. Just torching the bolts long enough darkened them alot. The last day in the dip helped a bit too.
Thanks guys
Brandon Wittwer
#9 posted 05-08-2010 08:26 AM
These bolts will get sat on. I’m hoping an oxide would not rub off like a paint could.
View wood247's profile
wood247
9 posts in 3009 days
#10 posted 05-08-2010 09:39 AM
Eastwood company makes a kit for doing just what you are looking for. Here is a link. Hope this helps.
http://www.eastwood.com/metal-blackening-kit-with-diamond-clear.html
View bluestone's profile
bluestone
2 posts in 2814 days
#11 posted 05-08-2010 03:23 PM
Novacan Black Patina for lead and solder. Available at stained glass suppliers. Works well on zinc.
