Gluing solid panels with caulk
Forum topic by 747DRVR posted 05-03-2010 11:17 PM 1448 views 0 times favorited 10 replies Add to Favorites Watch
View 747DRVR's profile
747DRVR
199 posts in 3264 days
05-03-2010 11:17 PM
I am making some white oak outdoor cabinets for my inlaws.The doors will be solid wood frame and panel doors.I was going to put the solid 1/4 inch panel in grooves like I usually do but now I am considering using rabbits in the frame.My question is would it be OK to glue the panels down with some caulk so the panels dont rattle around in our dry winters.These cabinets will be installed oudoors in the Florida Keys so I expect huge humidity changes.
10 replies so far
View Michael Murphy's profile
Michael Murphy
453 posts in 2912 days
#1 posted 05-04-2010 12:22 AM
Panels should float in the frame. Grooves definitely. Large changes in humidity would mean large amounts of shrinkage\expansion. Fasten them in and you will end up with cracked panels and\or broken joints. Make sure you leave enough clearance to allow for the expansion if you build them when it is dry.
-- Michael Murphy, Woodland, CA.
View lew's profile
lew
11944 posts in 3663 days
#2 posted 05-04-2010 12:26 AM
Space Balls!!
No kidding! I’ve also heard of folks using the rubber strips that hold screens in place on storm windows and doors.
View MyFathersSon's profile
MyFathersSon
180 posts in 3220 days
#3 posted 05-04-2010 01:38 AM
For reasons that escape me now – I have from time to time used rabbets instead of grooves.
The rabbets were deep enough to allow for a piece of 1/4” x 1/4” trim on the back to hold the panel in place.
Yes —Essentially creating a groove.
Just remember if you do this – to attach the back trim to the frame NOT the panel for reasons Michael mentioned.
-- Those who insist it can't be done - should politely refrain from interrupting those who are doing it.
View poroskywood's profile
poroskywood
618 posts in 3272 days
#4 posted 05-04-2010 02:09 AM
Space Balls
-- There's many a slip betwixt a cup and a lip.--Scott
View Gregn's profile
Gregn
1642 posts in 2891 days
#5 posted 05-04-2010 02:10 AM
I knew there was a name for them SPACE BALLS, I remember having read about them just haven’t picked any up yet.
747DRVR
#6 posted 05-04-2010 03:27 AM
MyFatherSon that is exactly how I was planning to build them.The reason for the rabbits is because the panels are a weird shape and a rabbit would make the panel easier to install than a groove.The reason I was thinking of the caulk is because I once read that a good way to make a substitute for spaceballs was by placing long strings of silicone caulk on some wax paper.When the caulk dries you can cut it up into different size pieces that goes into the groove.I thought about taking it a step forward and just putting to notthe caulk in and then adding the panel while the caulk was still wet.I was thinking that the caulk was flexible and weak enough to not split the wood.I think what I will do now is put a little bit of caulk in the rabbit and let it dry before I put in the panel
View scopemonkey's profile
scopemonkey
188 posts in 4071 days
#7 posted 05-04-2010 03:47 AM
I agree that space balls is a good idea. Another alternative I have used is to pin the panel with a brad from the back in the middle of the door. This prevents the panel from moving/rattling and still allows for expansion at the edges.
-- GSY from N. Idaho
View EZzinger's profile
EZzinger
8 posts in 2855 days
#8 posted 05-04-2010 08:09 AM
While considering the unusual environmental circumstances, you may want to examine the availability of latex surgical tubing in various diameters as a possible cure for your dilemma. You have an unknown seasonal dimension change to deal with, so you may want to consider a deeper than conventional groove. You can also consider applying a clear coat of sealer to all cut parts prior to assembly in order to reduce this moisture dilemma.
View Knothead62's profile
Knothead62
2581 posts in 2868 days
#9 posted 05-04-2010 02:42 PM
Humidity would take a backseat to hurricanes.
View mnguy's profile
mnguy
190 posts in 3305 days
#10 posted 05-04-2010 03:11 PM
I think what threw folks was your original post title “gluing with caulk”, when you were really on the same page as the space ball / tubing / screen spline folks. I think your idea of making a space ball by letting the caulk dry is a good one. I think you’d also be ok dropping the panel into a rabbet, putting a dab of caulk in your gap, letting that dry, then adding your trim on the back to hold the panel in.
