Forum topic by dakremer | posted 05-03-2010 07:22 PM | 36353 views | 2 times favorited | 27 replies | ![]() |
Topic tags/keywords: pine table top how to Hi fellow lumberjocks.
My girlfriend’s mom wants me to build her a pine table top that sort of looks like the picture I have posted below. She already has the base of the table wish has some turned legs, all black. All she wants me to build is the actual top to attach to the frame. Whats the best way of doing this? Can I just go buy some 2X10s or 2X12s from a big box store and plane them, beat them up, stain, etc, etc. Or do I need something special? I really have no idea how to do this.
If you have any experience on how to do something like this, I’d appreciate the help! Thanks a lot -- Hey you dang woodchucks, quit chucking my wood!!!! |
27 replies so far
#1 posted 05-03-2010 07:47 PM |
Go to a local used lumber place or check out a used furniture buisiness. You might either find the table period or at least a lot of the bits to cabbage one together. I mean cabbage in a good way. Consider large wardrobe closets that are buggered up and cheap. There might be leaves about from long lost tables. Maybe a bad table has good legs. A lot of times this type of recycling saves money and just looks darn better. Here I have the Habitat Re-Store Store to look through and a number of old furniture dealers. Of course you can go to one of the big boxes or even woodcrafters for you lumber. Just not as fun as the hunt. -- ~Just A Guy With A Hammer~ |
#2 posted 05-03-2010 07:48 PM |
I’m no expert, but I’ll give you some advice anyway. I recently built a small side table out of some simple 2×4s from HD. I looked for really straight grain and minimal knots, but that table looks like it’s got a bunch of knots so you wouldn’t have to be too choosy. To join my table top pieces together and to attach the top to the base, I simply used pocket holes. It’s extremely solid with no glue. If you want the piece to look distressed, I wouldn’t do much planing. To give it the aged look you can either buy a set of “aging” tools like these from woodcraft: You can buy them here: http://www.woodcraft.com/Catalog/ProductPage.aspx?prodid=28791 Or, you can just beat it up in the shop with a wire brush, chain, wood with nails in it, etc. Good luck! -- The secret to getting ahead is getting started. |
#3 posted 05-03-2010 11:23 PM |
Your options are many. If your looking for that real knotty look you could use #2 pine 1x’s and fix them to a sheet of plywood with a pine edging to hide the plywood for a top if desired. Just a suggestion here. -- I don't make mistakes, I have great learning lessons, Greg |
#4 posted 05-03-2010 11:53 PM |
I would get some construction grade pine at the local store and distress it. The construction grade lumber will have more knots and dings in it. I distress the wood by hitting it with a small chain. I also sometimes take a woodburning tool and make a few small dark tracks an inch or so long to look like worm tracks. Then stain it. -- Wayne - Plymouth MN |
#5 posted 05-03-2010 11:57 PM |
If you have an ‘old home supply’ or a salvage lumber yard somewhere near you, you might find some wide plank flooring that you could piece together to get that look. -- Kinky Friedman: "The first thing I'll do if I'm elected is demand a recount." |
#6 posted 05-04-2010 12:03 AM |
I’ve done a bit of this type work. 2X10’s from the bigCrap stores will be fir, which will work…kinda. That looks to be a 8 or 6 quarter pine top that has groves cut out with a chisel and a very light distressing. Then a glazed finish is applied. |
#7 posted 05-04-2010 12:17 AM |
Think pallets. Find some used pallets (usually made from oak, maple or other hardwoods) and you’ll have a nice source of pre-distressed wood. Carefully remove nails and staples, but leave the holes and dings. Sand to the desired finish then use dyes or stains to color the wood. Sometimes I’ll use used coffee grounds and used tea bags for a funky rustic stained look. Rubbing with wet walnut husks (wear gloves) will also impart some nice colors. A brushed on polyurethane varnish or even a spar varnish makes a good finish. Then, there is always old barn wood… -- 温故知新 |
#8 posted 05-04-2010 12:20 AM |
Get 2×8 or 2×10 pine glue them together with biscuits every 6 to 8 inches helps with alignment. Then plane top flat. Then throw a bunch of tools across the top or a chain is good too. Stain darker color in the tool marks the stain top the color u want. Then finish. Ive done several this way and the come out looking pretty good. U fan also stain table wait for it to dry then go over tool marks with darker color. -- Sparks |
#9 posted 05-04-2010 12:35 AM |
There is also the Festool planes with “rustic” cutting wheels. A little on the expensive side….but you can get the same idea to use on a hand or other brand plane (basically it is a blade that is convex or concave to give the look of hand scraping). Given the rest of the ideas above…you have a lot of options. I have made several of these “rustic” old style tables…etc…by request and it just depends on how rustic they want. For pine stuff…I typically like to laminate end grain together as the flat grain is so weak….you can distress the end grain also….with end grain the top is much more sturdy….and you won’t need to back it up with plywood or mdf for stiffening. -- Woodworking.....My small slice of heaven! |
#10 posted 05-04-2010 01:07 AM |
I’d bet you would score some major points if you made her a nicer top. Score some lower quality oak, or maybe even black walnut, slabs from a local sawyer and mount them on runners you will connect to the legs, and paint on the varnish. If you’re not worried of it’s being perfect, which is how it sounds, then make it better than “good enough” and be the hero anyway. -- Power tools put us ahead of the monkeys |
#11 posted 05-04-2010 02:13 PM |
I have seen this type of table top made from old barn wood. I can’t speak to the availability of old barn wood in Iowa, but around here it is pretty easy to locate. Good luck. pkennedy -- P Kennedy Crossville, TN |
#12 posted 05-04-2010 02:49 PM |
Find an old barn and go with the “Midnight Building Supply with the 5 Finger Discount” method. lol |
#13 posted 05-04-2010 03:14 PM |
If you are looking for “real” old looking stuff for the table top, and can find an old house being torn down, go for the floor boards, those are already worn and will have tongue and groove for aligning them. If you have to go the new route, try putting the boards down on a gravel driveway and carefully running over them to put in random marks and getting the dirt into the wood look, you can even drag them around behind the car for more marks, then assemble the table. The problem with trying to make new wood look old is the randomness. I like using a hand scraper and a belt sander, with a bag of rocks thrown in to just mix things up. Norm “The New Yankee Workshop” had a show about distressing a chair, showed the many steps in finishing to get that really worn look using paints, stains and waxes. -- James |
#14 posted 05-04-2010 03:16 PM |
Nomad~ I don’t think you understand the subjective word “Perfect.” Many of my clients would find that table pictured as Beautifully Perfect. It is sometimes harder to make a perfectly fine old piece then a perfectly fine new piece. The line.” She has the remains of a beautiful women about her.” Is a perfect statement of a nice old antique or well used piece of furniture. Seems to me dakremer is about to find out how much harder such a piece is to build. But also how much more fun. -- ~Just A Guy With A Hammer~ |
#15 posted 05-04-2010 11:08 PM |
what kind of stain do I use to get that color with Pine? or Do I use stain? maybe just an oil of some sort -- Hey you dang woodchucks, quit chucking my wood!!!! |
Forum | Topics |
Woodworking Skill Share
12035 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1372 |
Finishing
4909 |
6697 |
28075 |
CNC Woodworking
212 |
Hand Tools
5413 |
Jigs & Fixtures
1421 |
Wood & Lumber
6236 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4759 |
LumberJocks.com Site Feedback
2201 |
Coffee Lounge
8847 |
