A question of sole
« back to Hand Tools forum
Forum topic by Charlie383 posted 07-06-2016 05:47 PM 820 views 0 times favorited 7 replies Add to Favorites Watch
View Charlie383's profile
Charlie383
2 posts in 864 days
07-06-2016 05:47 PM
Topic tags/keywords: plane question
I am new to the site and looking for some information. I have a Stanly #27 transitional plane that looks to be in good condition until you look at the sole. The sole has been butchered to the point that you cant retract the iron far enough. Also it is out of square the good news is there is no checking or cracking. My plan is to square and true it up then laminate a piece to the bottom to bring it back to its original height. My question is what was the height of the original wooden sole?
7 replies so far
View BigYin's profile
BigYin
421 posts in 2590 days
#1 posted 07-06-2016 07:44 PM
few hints here … not the best resole video but ok
https://www.youtube.com/watch?v=ZcZTI3jMhio
-- ... Never Apologise For Being Right ...
View Don W's profile
Don W
18989 posts in 2742 days
#2 posted 07-09-2016 12:53 AM
1.5”
View bridgerberdel's profile
bridgerberdel
50 posts in 1416 days
#3 posted 07-18-2016 05:52 AM
The height thst yields the mouth opening you want.
-- occasional musings on my blog: www.bridgerberdel.wordpress.com
Charlie383
2 posts in 864 days
#4 posted 08-05-2016 04:43 PM
Thanks for the advice, the problem is that the sole has gotten so thin that the blade wont retract all the way.
View Kirk650's profile
Kirk650
574 posts in 922 days
#5 posted 08-06-2016 12:22 AM
I had a very similar problem with an old transitional plane I wanted to use. It needed a new wood body, but I was not going to be able to build it from scratch. So, I took the plane apart, milled the sole of the original wood about a half inch thinner. Then glued on a slightly thicker piece, using Hard Maple. Then, using the angles on the interior cuts of the original wood, I chiseled through the new wood. Then I ran it over the jointer till I got the thickness just right. It has a two toned body now, which I suppose gives it a resale value of $0, but it works fine.
View Marn64's profile
Marn64
296 posts in 960 days
#6 posted 08-07-2016 12:09 AM
You could graft on a new sole. I know some planes made by ECE Emmerich have a Lignum Vitae sole that is very attractive, so you could implement a similar sole on yours.
-- Benjamin, Milwaukee
View bandit571's profile
bandit571
21524 posts in 2857 days
#7 posted 08-07-2016 03:46 AM
Maybe get a blank of Beech, and shape to make a new base?
