UNO bedside table
Forum topic by hophinhan posted 07-06-2016 05:47 PM 675 views 0 times favorited 8 replies Add to Favorites Watch
View hophinhan's profile
hophinhan
2 posts in 776 days
07-06-2016 05:47 PM
hi guys, could you guys give me some opinions ‘bout this UNO bedside
i did a replica of it, here it is https://www.facebook.com/konohadecor/photos/?tab=album&album_id=252702671765214
And it’s actually not perfect, the top panel seem to be ‘go down’.
I used screws to joint them, with a hidden flat corner brace and it’s still not good enough.
Help?
8 replies so far
View bondogaposis's profile
bondogaposis
4899 posts in 2437 days
#1 posted 07-06-2016 07:08 PM
Full blind dovetails would be called for in that design, also keep the top short as possible. You’re trying to beat physics here, on your facebook page it looks like you scaled it up and made the top longer. There is really a limit to the length of the unsupported top.
-- Bondo Gaposis
View splatman's profile
splatman
586 posts in 1485 days
#2 posted 07-06-2016 09:35 PM
Reinforce the corners with angle steel set into rabbets such that with a bit of filler, they will be hidden.
Join the panels with flathead screws threaded into the angle. (inset 1)
If you use 2”(or wider) x 1/8” angle, the large surface of the angle will allow you to use epoxy or other strong glue (skip the fasteners).
Or cut slots and glue the angle into the slots like a spline. (inset 2)
View Woodknack's profile
Woodknack
12245 posts in 2466 days
#3 posted 07-07-2016 02:26 AM
Box joints.
View oldnovice's profile
oldnovice
7027 posts in 3454 days
#4 posted 07-07-2016 05:32 AM
Ditto Rick M.
hophinhan
2 posts in 776 days
#5 posted 07-07-2016 05:36 AM
Full blind dovetails would be called for in that design, also keep the top short as possible. You re trying to beat physics here, on your facebook page it looks like you scaled it up and made the top longer. There is really a limit to the length of the unsupported top.
- bondogaposis
Thank sir, but dovetails joint would be difficult for me ‘cause i’m really new to woodworking.
I think i’ll make it shorter and smaller overall. I made it 45cm long. Do you think i should make it abotu 35cm?
- splatman
Nice idea. In insert 1, i could use the router to make steel flush with the wood, do you think after painting i can hide the steel.
In insert 2, do you think biscuit joint can do same thing?
Box joints.
- Rick M.
I’ll try it.
View AlaskaGuy's profile
AlaskaGuy
4274 posts in 2395 days
#6 posted 07-07-2016 07:06 AM
Box joints.
- Rick M.
Yep
splatman
#7 posted 07-08-2016 07:02 AM
- hophinhan
Paint alone would not hide it, only sort of make it blend in. For the side/top connection, it would be hidden enough because it would be in a place few would look. For the side/bottom connection (which is under slightly more stress), it will show, sort of the same way as hinges that have been painted along with the door. If you wish it to be completely hidden, set it slightly below the surface, and go over it with any filler that will bond to both steel and wood. Auto body filler will do it.
I doubt biscuits would make the cut.
If I would have thought of box joints, I would have suggested it. Give it a try.
Best thing to do is try each joint type. Box joints, biscuits, lock miters, angle steel.
Attach 2 1×4s into an L shape, clamp into a vise, hang a bucket on the end and fill the bucket with weights till the joint breaks. Multiply the results by however much wider (front-to-back) the table is than the 1×4.
Matthias Wandel did a few joint strength tests. Those might give you a pretty good idea of what each joint type can do.
Woodknack
#8 posted 07-08-2016 05:50 PM
I think i ll make it shorter and smaller overall. I made it 45cm long. Do you think i should make it abotu 35cm?
- hophinhan
Yeah, 45cm is way too long. The top should be around 30cm.
My guess is the original was reinforced with steel dowels then covered with melamine.
