Anyone know what this is?
« back to Coffee Lounge forum
Forum topic by Brian Anderson - UBWoodman posted 05-03-2010 12:48 PM 1144 views 0 times favorited 5 replies Add to Favorites Watch
View Brian Anderson - UBWoodman's profile
60 posts in 2945 days
05-03-2010 12:48 PM
Anyone know what this?......it will probably be a re-finish project in the future but I need to know what it is…thanks
-- http://www.ubwoodman.com
5 replies so far
View Maclegno's profile
Maclegno
224 posts in 3055 days
#1 posted 05-03-2010 01:54 PM
A secret compartment for a Stetson? A Chamberpot holder? A wash basin? It looks as if it has a key which suggests a desk , but the drop-down surface isn’t protected which cancels that. The hole in the marble(?) is much bigger than the one in the wood, which is strange. And the whole slides out! I think it slides out for access, but is used with the flap down, but slid back.
I can’t wait to find out what it is, some antique dealer should know.
Gerard
-- Maclegno,Scotsman in Italy
View davidpettinger's profile
davidpettinger
661 posts in 3193 days
#2 posted 05-03-2010 05:12 PM
Ok, it is an antique wash stand. Basin in the top, the locked door is for keeping shaving razors, brushes and mugs locked up. The drop down front was for your towel brushes and mug. The odd shaped opening was for a squat vase type vessel that the waste water could be dumped into from the basin above. This vessel usually had a handle on it and could be inserted through the hole and also removed that way to empty its contents. This way you could wash up first, then dump the dirty water into the vessel under the bowl and then fill with clean water to start your shaving. The hole in the bottom shelf was reserved for the water pitcher to keep it stable and steady.
-- Methods are many,Principles are few.Methods change often,Principles never do.
#3 posted 05-03-2010 06:45 PM
The top is solid and does not lift up, the door also does not lock. It has six sides with a leg on each corner and there is bracing in an H shape beteween legs so nothing can sit below it. You could set a bowl in it but you would have to pull out the drawer and then place the bowl inside, the sliding part of the drawer is too wide open to set anything on it and slide it in.
View m88k's profile
m88k
83 posts in 2945 days
#4 posted 05-03-2010 10:17 PM
Maybe it’s a badly designed washstand? Just saying, not everything you find was built sensibly.
-- ~Mark
View jockmike2's profile
10635 posts in 4239 days
#5 posted 05-03-2010 11:26 PM
I know, it was used in magic shows, a pretty girl stuck her, well whatever, in the hole the magician sawed off the whatever part it was and walla, she limps off stage screaming!
