Best Cornhole Plans for Woodworkers?
Forum topic by nogeel posted 07-05-2016 05:05 AM 4334 views 2 times favorited 16 replies Add to Favorites Watch
View nogeel's profile
nogeel
77 posts in 1126 days
07-05-2016 05:05 AM
Topic tags/keywords: cornhole design question tip
Most plans for cornhole seem to be aimed at non-woodworkers wanting to make the simplest cheapest cornhole boards possible using may pocket hole jig 2×4 and plywood. I was curious what folks have done when they have a complete shop. What material make sense to spend extra money? My current thought is potentially box joints and a rabbet to inset the plywood top.
I was just curious how nice and how far folks have gone to make them?
-- Jeff, Tennessee
16 replies so far
View Nubsnstubs's profile
Nubsnstubs
1306 posts in 1787 days
#1 posted 07-05-2016 01:09 PM
My advise would be to keep your guard up and be prepared to use fisticuffs you think you might be on the receiving end…. ............. Jerry (in Tucson)
View Redoak49's profile
Redoak49
3343 posts in 2045 days
#2 posted 07-05-2016 01:39 PM
I used 2×4 but found good ones that I planned little on each side and ripped square. I used butt joints and deck screws for joints. The plywood used was Aruaco ply which is a very good plywood with good surface and almost no voids. I also used a primer and very good exterior paint.
I would not use a rabbit joint as it will leave a seam for the bags to catch on. Could you use box joints or dovetails or something like that….yes…but why. Mine is just butt joints but they fit well and it looks good.
But like everything else in woodworking, make it the way you want. The goal is to have a game to play unless you want to make a piece to show off your skills.
View ste6168's profile
ste6168
255 posts in 1228 days
#3 posted 07-05-2016 01:51 PM
I have built sets with maple frames, planed to 3/4” and 1/2” maple veneered ply. However, no special joints or anything. TBIII glue and kreg jig together, and I also build my sets to be “nesting.” One frame is inset about 3/4” so that the boards fit inside on another. There is nothing really crazy about my sets, except they are nesting and slightly nicer materials. I have built about 5/6 sets in the past several years. I would care if I never built another.
If I ever have enough spare time though, I would love to build a truly nice set, similar to the Colter Atelier boards. They are beautiful, but come at a cost.
http://www.colteratelier.com/
View johnstoneb's profile
johnstoneb
2971 posts in 2229 days
#4 posted 07-05-2016 02:10 PM
You are making it. I would make it from whatever I wanted and use whatever joinery I wanted. I really like the one ste168 has shown.
-- Bruce, Boise, ID
View GR8HUNTER's profile
GR8HUNTER
4153 posts in 769 days
#5 posted 07-05-2016 02:16 PM
- ste6168
is that a bubble level inlaid into it ?
ste6168
#6 posted 07-05-2016 05:39 PM
- ste6168
- GR8HUNTER
You are correct. Their sets sell for like 3k. Check out their website. Pretty wild, honestly. I personally would be scared to play cornhole on them, would just want to look at them.
View muleskinner's profile
muleskinner
897 posts in 2493 days
#7 posted 07-05-2016 05:52 PM
Hmmm … $2750 with tax for me. Free shipping, so there is that.
Truly, some people DO have too much money.
-- Visualize whirled peas
View Tideline77's profile
Tideline77
102 posts in 828 days
#8 posted 07-05-2016 11:34 PM
What method is used to make the circle ?
Would you laminate a square piece from small stock and then cut the circle out ?
If yes ?
What method to cut a perfect circle ? Inside and outside ?
A band saw with a narrow blade ?
Then sanded inside and out side the circle ?
If you don’t mind a rookie question ?
View emilime75's profile
emilime75
4 posts in 747 days
#9 posted 07-06-2016 12:45 AM
Hey, folks, new guy here and this is my first post.
Just thought I’d share the last project I’ve completed which is a set of corn hole boards. Built from Amber Plyboo, aluminum inserts, sprayed with clear lacquer in satin. I planned on doing more with the aluminum, but I ran into difficulties and out of time. These were a house warming present for good friends.
If you don t mind a rookie question ?
- Tideline77
Tideline, I find it best to cut circles using a router with a straight bit and a circle jig. I use the Jasper.
nogeel
#10 posted 07-06-2016 01:35 AM
Are these guys using solid wood? How are they keeping the joints in the frame and panel tight without any expansion?
-- Jeff, Tennessee
Tideline77
#11 posted 07-06-2016 02:05 AM
Looks great Emilime75
Thanks for the info also
View Woodknack's profile (online now)
Woodknack
12097 posts in 2437 days
#12 posted 07-06-2016 03:15 AM
Don’t skimp on the top. Too thin and it will be a trampoline, the bean bags will bounce right off.
nogeel
#13 posted 07-06-2016 05:06 AM
I ended up watching the video on their site and answered my own question. They used plywood and made a book and slip matched veneer on the top and the bottom.
The interesting thing about their video is it made me think of a cornhole board as nothing more than a table with two legs and a hole it it. The video on how they make the boards is worth a watch. Still can’t imagine paying $2,400 for cornhole boards, but it is well made.
-- Jeff, Tennessee
nogeel
#14 posted 07-06-2016 06:05 AM
The PlyBoo looks awesome BTW.
-- Jeff, Tennessee
nogeel
#15 posted 07-08-2016 03:36 AM
Any tips on cutting a circular inlay for around the hole?
-- Jeff, Tennessee
