Drawer Lock Router Bit
Forum topic by Joel_B posted 07-04-2016 04:12 PM 1003 views 0 times favorited 7 replies Add to Favorites Watch
View Joel_B's profile
Joel_B
347 posts in 1523 days
07-04-2016 04:12 PM
I need to make some drawers for my nightstand and decided to use the drawer lock method.
There are many drawer lock bits to choose from including:
MLCS
Inifinity
Freud
Rockler
Yonico
They vary in diameter from 1 to 2 inches. I am not sure why the diameter would matter other than a larger diameter might cut faster. Some have the option for a set up block. Since all the drawers will be made from the same stock I am not sure the set up block is really needed. The Yonico is the least expensive and is on Amazon Prime. Rockler is next cheapest and I could possibly pick it up at the local store. The drawer fronts will be white oak, I am not sure what to use for the sides. I don,t really want to use ply as the router bit might chew it up. I am thinking maybe poplar or alder. Thanks for any advise.
-- Joel, Encinitas, CA
7 replies so far
View Beaver_Lumber's profile
Beaver_Lumber
6 posts in 2440 days
#1 posted 07-04-2016 04:27 PM
Joel,
consider also CMT router bits. I have this brand for my lock drawer bit and it works just as good as Freud while being cheaper. Last winter I rebuild 4 drawers to replace the crappy ones that were falling apart in our kitchen. I used 1/2” baltic birch plywood and the result was flawless. Took a little time and 2 or 3 test cuts to make sure the setting was dialed right, but once setted it was a quick job…
If you have access to Woodsmith magazine, look at the issue 222 as there is an article specifically on using this type of router bit. I did use it as a reference while doing my drawers…
-- Patrick - A beaver is like a woodworker because it needs to have wood between its paws
View AlaskaGuy's profile
AlaskaGuy
4479 posts in 2451 days
#2 posted 07-04-2016 05:40 PM
You just can’t go wrong with Whiteside…......get the 1/2 shank.
http://www.woodcraft.com/Product/814944/LK-DR-12SH-1LD-12CL.aspx?gclid=CJqztvqs2s0CFdKIfgodv-kDrg
BTW what is your drawer material thickness?
View pintodeluxe's profile
pintodeluxe
5756 posts in 2955 days
#3 posted 07-04-2016 06:28 PM
Just like locking miter bits, get the correct diameter bit for your drawer stock thickness.
Rocket and Whiteside make good bits.
Joel_B
#4 posted 07-04-2016 11:54 PM
You just can t go wrong with Whiteside…......get the 1/2 shank.
- AlaskaGuy
I think 1/2 or 5/8 for sides and 3/4 for fronts
AlaskaGuy
#5 posted 07-05-2016 12:02 AM
- AlaskaGuy
- Joel_B
/blockquote>
I assume you’re going to make a draw box with 4 sides, a bottom and a separate draw front.
View BurlyBob's profile
BurlyBob
5911 posts in 2407 days
#6 posted 07-05-2016 12:07 AM
Totally agree Whiteside. They’re the best in my book.
AlaskaGuy
#7 posted 07-05-2016 12:08 AM
I’ve made a lot of drawer with dovetails (Leigh Jig) and box joints (Leigh jig) but don’t use those much anymore unless some ask or for something special.
For drawer I mostly use a lock rabbet joint . You can do it on the tables/no need to buy anything.
https://youtu.be/_V8MS0RDxCw
