Accidentally dyed floor purple! Help!
Forum topic by Cathie posted 07-04-2016 12:42 PM 2178 views 2 times favorited 37 replies Add to Favorites Watch
View Cathie's profile
Cathie
13 posts in 598 days
07-04-2016 12:42 PM
Topic tags/keywords: vinegar steel wool hardwood flooring purple iron acetate help
Hi y’all, I’m new to this site and forums in general. I’ve accidentally dyed my whole floor purple, I had it sanded professionally then I applied a steel wool and vinegar stain to the wood hoping for a light grey. I didn’t test patch, I didn’t water down, I should have, we all make mistakes, what’s done is done, any ideas on how to fix it? It’s Tassie oak or Vic ash (Australian hardwood). I would still like the result to be not too dark, am thinking of going over it with a mix polyurethane tinted with Jarrah and golden oak because those tones would help counteract the purple.. I was hoping for some kind of (hopefully natural) water based solution.. Any ideas? Thanks in advance – Cathie
37 replies so far
View waho6o9's profile
waho6o9
8100 posts in 2483 days
#1 posted 07-04-2016 12:50 PM
View CharlesNeil's profile
CharlesNeil
2240 posts in 3777 days
#2 posted 07-04-2016 01:07 PM
What you have is an iron stain, oxcylic acid AKA deck brighter should kill it and get you back to raw wood, http://www.walmart.com/search/?query=wood%20bleach%20oxalic&typeahead=wood%20bleach
you will probably need to do a light sand with some 180 or 220 after it dries to remove some raised fiber, but its quick and easy, just give it a good hand sanding with the grain .
When your done bleaching wipe it down with a solution of 1 tablespoon of baking soda to 1 qt of water to neutralize the bleach .
View bondogaposis's profile
bondogaposis
4609 posts in 2258 days
#3 posted 07-04-2016 01:21 PM
Experiment on scraps until you get the look you want. Then do the floor.
-- Bondo Gaposis
116906 posts in 3484 days
#4 posted 07-04-2016 01:25 PM
Cathie
You lucked out with the first answer from Charles Neil, he is a finishing expert of many years experience and has taught classes and written books on the subject of finishing.
Cathie
#5 posted 07-04-2016 02:05 PM
Thanks guys, Charles, I shall have a look round to see if I can find a simular product available in australia. Your input is much appreciated gentlmen. Thank you!
Cathie
#6 posted 07-04-2016 02:09 PM
Charles, are you able to please tell me if this product would suffice? https://www.bunnings.com.au/intergrain-4l-reviva-timber-cleaner_p1563243
It’s available at my local hardware store.
CharlesNeil
#7 posted 07-04-2016 02:19 PM
Cathie,
Looks like it should do the trick,
View Sawdust2012's profile
Sawdust2012
112 posts in 1619 days
#8 posted 07-04-2016 02:44 PM
Paint the walls a complimentary color, or get a gold couch and rent to an LSU fan. Just make sure you get a deposit.
View HerbC's profile
HerbC
1721 posts in 2766 days
#9 posted 07-04-2016 03:36 PM
- Sawdust2012
Probably not too many LSU fans in Australia.
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View BigTreeBC's profile
BigTreeBC
8 posts in 611 days
#10 posted 07-04-2016 04:06 PM
I’ve played around a bit with the steel wool and vinegar solution and the colour you get seems to depend partly on how long you let it sit ( how much metal you dissolve into the solution) and what the wood wants to do. As mentioned it’s all about testing on scrap first to see what the colour comes out as.
I’ve stained directly over the mix before with good results but you can’t go lighter.
I don’t mind the current look.
CharlesNeil
#11 posted 07-04-2016 05:08 PM
Keep us posted, will be out of the loop for a week or so, but then we can talk about achieving “grey” or is it Gray.
In either case its hard to achieve, a photo of what your looking to achieve would help alot .
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2216 days
#12 posted 07-04-2016 05:32 PM
- CharlesNeil
I looked up “grey and Gray…....They have the same definition.
View Kelly's profile
Kelly
1918 posts in 2851 days
#13 posted 07-04-2016 07:47 PM
Protect your lungs when sanding. Oxalic acid is nasty stuff.
- CharlesNeil
woodbutcherbynight
3957 posts in 2315 days
#14 posted 07-04-2016 08:43 PM
Purple is good!
View splatman's profile
splatman
586 posts in 1305 days
#15 posted 07-04-2016 10:55 PM
Just call it Purpleheart. :D
showing 1 through 15 of 37 replies
