Waterstones - opinions
Forum topic by Betsy posted 341 days ago 655 views 0 times favorited 18 replies Add to Favorites
View Betsy's profile
Betsy
1854 posts in 424 days
341 days ago
I’ll be attending a hand tools class in May and am working on getting stuff together that the instructor recommends bringing. This is a traditional class that will be using water stones for sharpening. I’m looking forward to having a “live” person show me his sharpening techniques. So far my sharpening has not been spectacular.
It seems like Lee Valley has the best prices on water stones. Here are my questions.
Are combination stones ok for the hobbiest who is machine oriented but wants to include hand tools? I’m talking about the stones that are one grit on one side and another grit on the other. Combination stones seem to be less expensive than individual stones. My thought is would I ever completely use up a combination stone so that I would be replacing them soon.
Is a flattening stone completely necessary or will sandpaper flatting be ok. I don’t mind spending on a flattening stone if I need to.
Also, I was at Rockler last week and they have a brand “King” stones. Are these good stones.
So far most folks I’ve talked to say I should get the Norton stones.
I know that everyone has opinions on sharpening and, like finishing, arguments can be made for all sides. I do want to hear opinions so I can weigh them and make an informed decision for myself.
Thanks all.
-- Betsy - GO BUCKS!
View Mike Lingenfelter's profile
Mike Lingenfelter
403 posts in 642 days
341 days ago
The combination stones are a good place to start. They are just as good as the full stones, they just won’t last as long. With that said it will take a “part-time” woodworker a long time to go through one of the combination stones. I have Norton stones and they are really nice. I’ve heard good reviews and experiences with King stones.
I through the Norton “Flattening Stone” away. What a waste. I started out using sandpaper to flatten my stones, but have moved to using a DMT (diamond) stone to flatten my water stones. I’ve watched Rob Cosman DVDs and he uses a 1000 grit water stone to flatten his stones. Rubbing two stones together will produce 2 flat surfaces.
-- http://theinquisitivewoodworker.com/
View mot's profile
mot
4851 posts in 565 days
341 days ago
I use to have combo stones and after realizing that I could use my 4000 stone to flatten my 8000 stone, I got away from them…
13167 posts in 929 days
341 days ago
Frank Klausz in his class on sharpening uses sandpaper taped to Melamine.
And he uses Norton stones.
Betsy
341 days ago
All in all though it sounds like its not a bad way to go to see if I would like water stones. The cost between individual stones and combination stones is kind of surprising. I’ve got a while to think on it before I get any.
Tom when you used combo stones were you happy with them with the exception of the flattening issue?
Now back to the using two stones to flatten one another. I’m assuming you start with clean stones before you flatten. But doesn’t the grit from one get embedded in the other? Is the amount of grit transferred simply to minimal to worry about?
View Bob N's profile
Bob N
40 posts in 455 days
341 days ago
I have the King water stones and I am very satisfied with them. These are the stones that David Charlesworth uses in his teachings and lateset DVD’d on sharpening. The one thing to consider on the combination stones in my opinion is that when one side wears out, what then? Also it would seem logical that each side will only last half as long as a full stone. Sandpaper and glass are fine for flatening, although I personally use the Norton flatening stone and have had good results with it so far.
This is all based on my personal opinion and experience and your mileage may vary of course.
View cajunpen's profile
cajunpen
5345 posts in 594 days
341 days ago
Betsy, for what it’s worth, when I purchased my Veritas BUS Plane from Lee Valley I asked for a recommendation as to which was the best buy for a water stone. The advised this one and I bought the more expensive of the two. I have been very satisfied with it, although I have not had to flatten them yet. I am thinking about getting a diamond stone for flattening – or I may just use a piece of granite that I have laying around with some 200 or better grit sandpaper stuck to it.
View mot's profile
mot
341 days ago
Betsy, yes, the combo stones were fine except for the flattening.
Mike Lingenfelter
341 days ago
The question of cross-contamination from the courser stones to the finer stones was asked of Rob, and he said he never had any issues with it. Most people put all their stones in the same water, which would have grit from all the stones anyway. Me, I’m a bit of a neat freak. I have another bucket of water I use to rinse my stones off, before putting them back in to soak.
David Charlesworth in this books and DVDs has used sandpaper to flatten his stones. He will use a different sheet of sandpaper for his courser stones, than for his finer stones. David has also talked about using a DMT stone to flatten his stones. You need to use the Course or Extra-Course for this. The finer DMT stones will not last long the water stones. Sandpaper seems like a “cheap” solution, until you start to add up all the sheets you start to use. I also seem to run out of sandpaper when I really need it.
I think if you rinse your stones off you shouldn’t have any problems.
Betsy
341 days ago
Thanks Mike. I’m finding that sandpaper is pretty expensive. I’m not sure if I’ll like water stones or not, but the class calls for them so I’m going to invest in some. If I end up liking another method or can find a method I’m sucessful with, I can always sell them on e-bay!
Mike Lingenfelter
340 days ago
Yes, eBay or even here you might find some takers.
I sure if you asked 100 people how they sharpen their tools, you will get 100 different answers :). I think mine is a blend of several different styles.
The new Shapton GlassStones is a nice new technology (less messy), but you have buy a $290 Lapping Plate for the system to work! Talk about a steep price to get it.
Mike Lingenfelter
340 days ago
I was reading a little more about the Shapton GlassStones. I was told you needed to buy that expensive Lapping Plate, but now I found some information that says you can use sandpaper to keep them flat. I guess I should really stop listening to those salesmen :).
Betsy
340 days ago
I’m really looking forward to giving the water stones a try. I’ve not had much luck with the scary sharp system. Not sure why, but I’m not giving up until I have sharp, sharp chisels and plane irons!
View Daren Nelson's profile
Daren Nelson
364 posts in 434 days
340 days ago
”but I’m not giving up until I have sharp, sharp chisels and plane irons!”
That’s the spirit! I have not weighed in until now. I am going to blog how I sharpen soon. I have a shop made “finishing” stone I use (and as the name implies, I make) I can see my reflection on the honed surface.
-- Urban logger, http://nelsonwoodworks.biz/
Betsy
340 days ago
Cool Daren – I’ll be looking for the blog!
View Dorje's profile
Dorje
1749 posts in 525 days
340 days ago
I use the King or other brand stones – I’d have to go look. Very happy with water stones in general. I have a 1000, 3000, and 6000. I’d recommend gettting the full single grit stones…if you buy them, you’ll want to use them. Also, get the largest size you can afford. I really only need the 1000 and the 6000. Some people like a 1000 (or 1200) and 8000 set.
The kicker is keeping them flat! You have to do this with regularity. I like Mike’s strategy of the DMT diamond stone to keep them flat…that’s a great idea and what I’ll likely do in the future. For now, it’s silicon carbide wet/dry paper on 3/8” plate glass…but, you can go through that pretty fast! I also have one of the Norton flattening stones, but you have to flatten that occasionally too…I only use it with the 1000 stone.
View Kaleo's profile
Kaleo
194 posts in 668 days
340 days ago
I would recommend buying individual stones. Only because you won;t have to reach in a flip them when you need the new grit. And flattening the stones with sand paper is fine. What I do is use some 3M Adhesive spray and temporarily glue the sand paper down on a 1/2 inch piece of glass. Strike a few pencil marks across the stone and sand until all the pencil marks are gone. Then you know it’s flat. Good luck with your classes.
-- Kaleo , http://www.kaleosworkshop.com
Daren Nelson
340 days ago
Like Mike said ask 100 people and get 100 answers, maybe more ;). It’s weird I was just talking to my Dad about this last week. He has used natural stones for 40+ years, and taught me how to sharpen 30(?) years ago with them. He said he had switched almost entirely over to diamond plates. He has one pocket stone for his knife, but everything else is done freehand on diamond.
So everyone has their preference, and I guess can change it too.
View furnitologist's profile
furnitologist
170 posts in 541 days
339 days ago
Just within the past few weeks with the help of Matt over in the Basment, made the switch to water stones. Very happy with the results. Hardest part was figuring out the best way to contain the water. Over time mess was contained and excellent results attained. Ended up purchasing DMT Diamond (Course/X Course) good cutter, Norton 1000 and a Norton Combo 4000/8000. Once a year I always start out with real good edges but because I sharpen free-hand on the fly, by the end of the year some irons look pretty bad.
Bookmark And Share This Page
