Hand saw recomendation?
Forum topic by DaveC posted 02-16-2007 11:03 PM 2293 views 0 times favorited 8 replies Add to Favorites Watch
View DaveC's profile
DaveC
39 posts in 4389 days
02-16-2007 11:03 PM
I am looking at purchasing some hand saws. (good ones)
I am looking at the following:
Adria small tenon saw (crosscut)
Adria small tenon saw (Rip)
Lie-Nielsen straight handled dovetail saw. (rip)
(That comes to nearly $400.00)
If money were no object I’d just get them all (and I may eventually) However I have some other purchases to consider.
I am wondering if just one of the above might work well enough for cutting tenons and dovetails until I can afford to buy another. My thinking is that an Adria tenon saw filed in a rip configuration might work well enough for crosscutting because of the thin kerf that I may not need to get the crosscut saw right now.
Any advice?
Dave.
-- Dave.
8 replies so far
View Ethan Sincox's profile
Ethan Sincox
767 posts in 4414 days
#1 posted 02-16-2007 11:39 PM
I have the Adria dovetail saw. I picked it up a few years ago and probably paid $125 (?) or so for it. It was one of the first tool buys I ever made.
To be honest with you, I use my $30 Dozuki saw more often.
-- Ethan, http://thekiltedwoodworker.com
View Corndog's profile
Corndog
30 posts in 4365 days
#2 posted 02-16-2007 11:46 PM
I second the Japanese saws. A joy to use.
-- I've got a bandsaw in my kitchen...
DaveC
#3 posted 02-17-2007 05:01 AM
I have a nice Dozuki but I cant seem master the technique. If I could cut a straight line with one I would love to use them.
Dave.
-- Dave.
View scottb's profile
scottb
3648 posts in 4567 days
#4 posted 02-17-2007 07:01 AM
Practice Dave, that’s all. I have a cheap japanese pull saw I got at a local hardware store (but not a big box, because they don’t seem to stock replacement blades). I use this more than just about any hand tool for all sorts of jobs. Using a speed square to help me establish a line on two adjoining planes, I can quickly cut a perfectly square end off a 2×4 everytime. Learned that tip from one of Christopher Schwarz blogs. I recall some handsaw (japanese) excersizes in another mag, Woodwork, I think. I’ll see If I can’t dig that up.
-- I am always doing what I cannot do yet, in order to learn how to do it. - Van Gogh -- http://blanchardcreative.etsy.com -- http://snbcreative.wordpress.com/
DaveC
#5 posted 02-17-2007 08:19 AM
That would be great.
I really would like to be able to use such a saw. I have tried. I seem to be left to my own to figure out what I am doing wrong. The blade is so thin and flexible that I usually get a curved line and even if I do manage to get the line started straight It gets off track and I can not get it back.
I know that it must be technique otherwise no one else would use them. I can cut much more accurately with a full size 26” hand saw than I can a dozuki. : )
-- Dave.
View Obi's profile
Obi
2213 posts in 4477 days
#6 posted 02-17-2007 04:03 PM
I try to avoid using a hand saw for cross cutting because i suck at it. The chop saw or the new sled I made for the table saw works so much more efficiently . And I too bought one of those cheap pull saws from the local stick/tool/particleboard peddler and why is it that they don’t sell replacement blade? Are they indestructable? And I use mine just to cut dowels off flush. That in itself was worth the $12.00 I spent on it. Besides it was on a gift certificate that I got for Christmas. Christmas 2005 lasted almost a year, wonder what Christmas 2006 is going to do?
scottb
#7 posted 02-17-2007 05:38 PM
Dave – Use a Guide block for hand cutting – clamp it in place and use your left hand (presuming right-handedness) to hold the blade flush to it. I did this recently to cut wall studs at an angle, along a staircase to change the full wall into an exposed kneewall w/rail and spindles, with great success. Can’t take a wall to the chop saw.
If you go off course, back up and start cutting again, can’t correct otherwise. Not sure why, but I have a much easier time with my pull saw, than I’ve ever had with any western style saw.
Obi – Those cheaper saw blades are replaceable, (prob need to order from manufacturer – Fortunately a smaller (non-chain) hardware store near me carries blades) because the metal is hardened and not resharpenable. But unless you abuse it,(blindly cut into old walls, hitting nails, plaster and Lord knows what else – as I do on occassion) they do last a good long time.
View Philip Edwards's profile
Philip Edwards
245 posts in 4679 days
#8 posted 02-17-2007 08:21 PM
Dave
I have the crosscut Adria tenon saw – it is amazing!! I would recommend that as your only saw as it will cut dovetails and do clean crosscuts. Later if you decide to add a rip dovetail saw you still will have loads of use from the Adria.
Hope this helps
Phil
