Preventing cracks overnight
« back to Woodturning forum
Forum topic by fadi posted 07-03-2016 08:01 PM 781 views 0 times favorited 8 replies Add to Favorites Watch
View fadi's profile
fadi
4 posts in 668 days
07-03-2016 08:01 PM
Topic tags/keywords: lathe turning
Hello all,
What do you guys do when you start turning a blank and cannot finish it same day? I was turning my first bowl but cpuld not finish it same day. When I came back to it, it had cracked from multiple places along the gain lines.
8 replies so far
View JAAune's profile
JAAune
1788 posts in 2286 days
#1 posted 07-03-2016 08:06 PM
Put the shavings in a plastic bag then cover the blank with the same bag. That keeps all the moisture contained with the bowl.
View Ron Ford's profile
Ron Ford
208 posts in 1702 days
#2 posted 07-04-2016 09:17 PM
I agree with the last reply, but if you would prefer to keep the piece on the lathe and not lose registration, you can wrap a plastic shopping bag around it and tape it closed at the spindle. That is usually more than enough to stop cracks and splits.
-- Once in awhile I make something really great. Most days I just make sawdust.
View rustfever's profile
rustfever
751 posts in 3280 days
#3 posted 07-04-2016 09:25 PM
Shrink wrap film, several layers totally enclosing the wood turning.
-- Rustfever, Central California
View bigJohninvegas's profile
bigJohninvegas
441 posts in 1431 days
#4 posted 07-12-2016 05:54 PM
I agree with all of the above. I have used a spray bottle to wet it. Wrap a wet rag around it, and plastic grocery bag it. Leave it mounted to the chuck. Sometimes I have had it get a little mold on it. Thats ok. Wipe it down with a little bleach water mix and keep on turning.
-- John
View soob's profile
soob
258 posts in 1178 days
#5 posted 07-12-2016 07:33 PM
Wrapping it in a plastic bag (like a walmart bag) is all it takes.
View Tootles's profile
Tootles
808 posts in 2471 days
#6 posted 07-14-2016 07:38 AM
I hate to ask, but if it is going to crack when it is only half finished, won’t it just crack when it is finished? And if so, should one of the techniques described above be used to prevent that?
-- I may have lost my marbles, but I still have my love of woodworking
bigJohninvegas
#7 posted 07-14-2016 12:58 PM
Sometimes it will still crack. Most of the time it will be ok. Final turning of green wood survives best when turned to a thin uniform thickness. It will warp and move on you as it dries still, and you never know just what your are going to get. That is what I personally like about it.
I also never start a green wood turning unless I think I can finish it in one session. But as we all know life happens, and for one reason or another we half to stop in mid turning. The tips described here will help, hopefully save the project that would surely fail.
-- John
View soob's profile
soob
#8 posted 07-14-2016 01:11 PM
Thick (or just unhollowed) pieces are much more likely to check than thin ones. Finish can prevent it, too.
