Cutting Biscuits by Hand
Forum topic by JBahou posted 05-01-2010 10:05 PM 3767 views 0 times favorited 10 replies Add to Favorites Watch
View JBahou's profile
JBahou
15 posts in 3210 days
05-01-2010 10:05 PM
How do you cut biscuits by hand? Can you cut biscuits by hand?
Thanks,
-- Jack †
10 replies so far
View Gregn's profile
Gregn
1642 posts in 3222 days
#1 posted 05-01-2010 10:41 PM
If your referring to the biscuits themselves yes you can. How have I done it in the past? I took the size biscuit I wanted and traced it onto my material and then used the scroll saw to cut them. I imagine you could cut them on the band saw, but this was a sit down job at the time. Never tried it with hand tools.
View Eli's profile
Eli
141 posts in 3245 days
#2 posted 05-01-2010 11:35 PM
Again, if you’re talking about the biscuits themselves, they are better if you cut them by hand, because you can make them from solid wood and arrange the grain for strength.
Eli
JBahou
#3 posted 05-02-2010 12:47 AM
Okay, that’s some good information. Say I wanted to cut the holes for the biscuits as well, what method(s) or options are there that would be recommended?
For instance: drilling it out, lowering the work piece onto a router bit etc, etc.
Thanks!
-- Jack †
View uffitze's profile
uffitze
199 posts in 3193 days
#4 posted 05-02-2010 01:19 AM
If you have a router, you can get a router bit that will cut the slots.
If you are limited to hand tools, I’d suggest just cutting a mortise and tenon. Of course, it really depends on the application.
View juniorjock's profile
juniorjock
1930 posts in 4004 days
#5 posted 05-02-2010 01:42 AM
Isn’t the reason for using a biscuit because when you apply the glue to it, it expands in the joint?
View poopiekat's profile
poopiekat
4405 posts in 3973 days
#6 posted 05-02-2010 02:17 AM
Is there some reason why you don’t want to invest in a proper biscuit slot-cutter and a bag of biscuits? I mean if not, then just get a spline-cutter for your router and do splines instead. It’s crazy to attempt to re-invent the wheel, and biscuits themselves are a marginal method of construction in the first place.
View araldite's profile
araldite
188 posts in 3642 days
#7 posted 05-02-2010 03:09 AM
You can buy a thousand for about $30. That’s three cents a piece. Not worth the time to make. If you only need a few, it’s faster to cut splines like poopiekat suggests.
-- Failure is the road to success if you learn to learn from your mistakes - Vince, Greenville, SC
View studie's profile
studie
618 posts in 3385 days
#8 posted 05-02-2010 05:23 AM
An old TV show “Petticoat Junction” episode the cook just poured out the pancake batter on the grill, then used a cookie hole cutter to stamp out the pancakes. The remnant was just the same as the head gasket for an old ford flathead V8 that a stranded visiter in town was waiting for 2 weeks delivery!
-- $tudie
TopamaxSurvivor
18423 posts in 3914 days
#9 posted 05-02-2010 06:12 AM
Just use a mortising chisel and go to work :-)
View Eli's profile
Eli
#10 posted 05-03-2010 03:59 AM
If you’re going to hand cut everything, and just make it square and call it a loose tenon. Those are even better than biscuits because they provide some structural integrity.
Eli
