strongest corded drill
Forum topic by rmeir posted 07-02-2016 02:06 PM 1363 views 0 times favorited 17 replies Add to Favorites Watch
View rmeir's profile
rmeir
17 posts in 2473 days
07-02-2016 02:06 PM
hi i have been making bowls out of very hard maple,. I am using a makita 5/8 hammer drill and framag bits and what happens is that the bit begins spinning in the chuck and even at best, at a slow speed wont cut thru the wood. the bit is not brand new but i would call it reasonable sharp. I am thining the drill doesnt have the powewr to handle a big fostner. I have tried to read up on it and it seems like the makitas have a low torque and that creates the problem, a brand like dewalt has more torque and i might add a better chuck to hold onto the drill bit better. any suggestions as to strenght of drill etc.? also when i thighten the chuck i tighen all three of the little holes not just one
17 replies so far
View TheFridge's profile
TheFridge
10718 posts in 1686 days
#1 posted 07-02-2016 02:11 PM
Tighten all the holes won’t make a difference. Pretty sure the dewalt will have a 5/8 chuck as well. The dewalt has more torque but it won’t help if the bit will slip in its chuck too.
View Gene Howe's profile
Gene Howe
11063 posts in 3628 days
#2 posted 07-02-2016 02:21 PM
I’m betting your bit has a round shank. A hexagonal shank would likely solve your problem.
TheFridge
#3 posted 07-02-2016 02:39 PM
I m betting your bit has a round shank. A hexagonal shank would likely solve your problem.
- Gene Howe
Yep
View Slemi's profile
Slemi
117 posts in 1741 days
#4 posted 07-02-2016 02:43 PM
- Gene Howe
Yep
- TheFridge
You can just file it on three sides. Just a little and it will solve your problem.
runswithscissors
2892 posts in 2225 days
#5 posted 07-03-2016 12:06 AM
The strongest (with most torque) drills have triple reduction gearing, usually with a 1/2” or 5/8” chuck. The most powerful ones can actually hurt you if the bit should hang up. The old Milwaukee Hole Hawgs were known as wrist busters. Newer models have a clutch for low speed/high torque drilling. Dewalt comes to mind also, and I have an old B&D Timberwolf with the same features. This is from the old days, when B&D actually made industrial grade tools, not the cheap crap that company makes now.
I agree that grinding or filing 3 facets or the drill shank will prevent spinning. It is a bit challenging to get them spaced exactly right, and have them all ground evenly. Maybe somebody can weigh in on that?
View Woodknack's profile
Woodknack
12430 posts in 2580 days
#6 posted 07-03-2016 05:17 AM
That explains the drill bits I find that are ground on 3 sides and all of them wobble. Yeah, unless you are machinist, don’t even try it.
OP, it seems like you will be spending as much as a coring system would cost.
View bigblockyeti's profile
bigblockyeti
5285 posts in 1920 days
#7 posted 07-03-2016 01:20 PM
The Milwaukee 2404-1 is a 1 1/4” drill, one of if not the most powerful hand drills you can buy. It doesn’t use a three jaw chuck, it uses a #3 morse taper as no one would be able to adequately tighten a three jaw chuck by hand. Adapters are available to allow the use of a three jaw chuck. What it sounds like you really need is a hex shank on the bit you’re trying to turn.
woodbutcherbynight
5697 posts in 2609 days
#8 posted 07-04-2016 08:59 PM
A DRILL PRESS as well as shank end bits. This will allow you to control the feed rate better and raise up and clear the bit as it slowly goes through the wood. Think of it as good excuse to upgrade.
View BigTreeBC's profile
BigTreeBC
8 posts in 904 days
#9 posted 07-04-2016 09:06 PM
How big of a bit are you using?
Have you tried starting with a smaller pilot hole and working your way up? A smaller bit will meet less resistance and reduce the chance of it spinning in the jaws.
View AZWoody's profile
AZWoody
1413 posts in 1424 days
#10 posted 07-04-2016 09:53 PM
- BigTreeBC
Wouldn’t that be dangerous with a Forstner? Without the center point able to set in before the cut, the bit could kickout pretty easy.
View Arlin Eastman's profile
Arlin Eastman
4251 posts in 2761 days
#11 posted 07-04-2016 10:23 PM
Why don’t you use a Jacobs Chuck on the lathe tailstock and drill the hole?
-- It is always the right time, to do the right thing.
BigTreeBC
8 posts in 904 days
#12 posted 07-05-2016 05:12 PM
Good point, some how I missed the forstner bit part. I think I saw framag and thought framing thinking regular brad point.
I usually take forstner bits to the drill press though, especially for bigger holes, it saves your wrists a lot of punishment.
Drill power should be sufficient on any hand held though, the problem is that with hand helds its difficult to precisely control your feed speed to cut at a rate the drill can handle. Power just lets you do it faster.
Push to hard/to fast and something will have to give, as it’s the bit slipping in the chuck, there’s your problem, not the drill power.
- BigTreeBC
Wouldn t that be dangerous with a Forstner? Without the center point able to set in before the cut, the bit could kickout pretty easy.
- AZWoody
View Ocelot's profile
Ocelot
2113 posts in 2838 days
#13 posted 07-05-2016 08:58 PM
I have a Bosch corded drill with 1/2” chuck which I bought to mix mortar. I would chuck up the mortar mixing paddle which was about 24” long. If I didn’t hold the 5 gallon bucket firmly between my feet, it would spin the bucket with the mortar mixing paddle – half full of thinset. I can’t imagine it stalling with a forstner bit.
I think I paid $99 for it at one of the big box stores 15 years ago.
-Paul
View josephf's profile
josephf
207 posts in 2296 days
#14 posted 07-06-2016 04:11 AM
had a chuck just fail on me . keeps loosening up now .maybe they just wear out . you might look for a used milwaukee hole hog .they have two speed transmission ,made for heavy loads . just seems like finding another heavy corded drill should be easy with all this cordless stuff on the market corded ones gather dust .
View Plain's profile
Plain
157 posts in 898 days
#15 posted 07-06-2016 04:44 AM
Take one of those rotary hammers with SDS+ chuck. I have Bosch and it drills into concrete maybe 50 times faster than a hammer drill. You also need a proper bit
https://www.amazon.com/gp/product/B00VGECCAU/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A1THAZDOWP300U
