Anybody use Bamboo or Lumboo lumber
Forum topic by Dan Hux posted 05-01-2010 05:26 AM 10578 views 1 time favorited 17 replies Add to Favorites Watch
View Dan Hux's profile
Dan Hux
577 posts in 3397 days
05-01-2010 05:26 AM
Have any of you ever used this type of Bamboo or lumber. Here’s a link, I was interested in trying it, but I swear it’s the ugliest stuff i’ve seen in my life. I’ve posted a link, have a look please
http://www.calibamboo.com/bamboo-lumber-lumboo.html
If you’ve used it,,what did you think?
Thanks,
dan
-- Dan Hux,,,,Raleigh, NC http://whitdaniel.com
17 replies so far
View John Steffen's profile
John Steffen
218 posts in 3078 days
#1 posted 05-01-2010 05:38 AM
I’ve never used it, so I might be totally wrong, but from the pictures it looks like it has a lot of voids.
I’m all for bamboo products, but this doesn’t look great.
-- Big John's Woodshed - Farmington, IL
View Gene Howe's profile
Gene Howe
10521 posts in 3451 days
#2 posted 05-01-2010 02:21 PM
I’ll pass.
View Ger21's profile
Ger21
1074 posts in 3154 days
#3 posted 05-01-2010 02:29 PM
That “fence post” lumber is not the type of bamboo you’d use for building furniture. That looks like a low cost product for exterior use.
With normal bamboo lumber, there are no voids at all. It’s easy to work with, and cuts a lot like red oak. It splinters very easily on crossgrain cuts. It also has a very unique smell.
Last year we did a job that used about $25,000 worth of bamboo. We had bamboo “plywood” shipped direct from China, and also purchased a lot “lumber”. Typically like the 3 ply plywood and stair treads here.
http://www.nwbamboo.com/materials.html
There are no voids at all in bamboo. It’s easy to work with, and cuts a lot like red oak. It splinters very easily on crossgrain cuts. It also has a very unique smell.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View richgreer's profile
richgreer
4541 posts in 3097 days
#4 posted 05-01-2010 02:31 PM
We put some bamboo flooring in our house and I had quite a bit left over. I’ve used it in a number of projects and I really like it. The flooring came pre-finished with a very beautiful and rugged finish. Therefore, I always have to find a way to hide the edges and the back.
Bamboo is a great “wood” to work with. Note that, technically, it is not a wood – it is a grass. I like telling people that we have a grass floor.
View JJohnston's profile
JJohnston
1622 posts in 3314 days
#5 posted 05-01-2010 05:27 PM
They say it’s affordable, but a single 2×4x8’ is $8.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View Planeman's profile
Planeman
97 posts in 3600 days
#6 posted 05-01-2010 05:36 PM
I have used bamboo for years in model airplane building in various places. Its the strongest, toughest wood I know of. Almost like using carbon fiber rod!
Rufus
-- Always remember half of the people in this country are below average.
View Lee Imbimbo's profile
Lee Imbimbo
69 posts in 3095 days
#7 posted 05-01-2010 05:39 PM
i have no experience working with Bamboo lumber, however, I do know that the earliest versions of bamboo flooring had major issues with flexing and warping after installation. So you may need to take into account a significant shifting in the wood lumber in your designs. You might just experiment with a few pieces in different environments and see how they react to different levels of humidity.
the fence posts in the picture have an odd similarity to spam. I just can’t help put think that they are just long tubes of spam =P
View JasonIndy's profile
JasonIndy
187 posts in 3458 days
#8 posted 05-01-2010 07:43 PM
“Large bamboo poles are shredded into strips and configured into a matrix optimized for structural integrity. Once the bamboo matrix is built a low VOC resin is added and the bamboo is placed into a hydraulic press which compresses the material at several hundred thousand pounds of force. The result is an extremely dense bamboo block and is nearly indestructible. The bamboo block is then milled and sanded into the world’s first dimensional bamboo lumber: LumBoo™”
I dunno, doesn’t sound very ‘au naturel’ to me.
View Steve Peterson's profile
Steve Peterson
377 posts in 3105 days
#9 posted 05-03-2010 06:06 PM
Interesting. They mention termite resistance, but then say that it should be sealed. They don’t really mention if it is useable for fence posts, but that seems like a great use.
One other thing that seems odd is that the size of a 2×4 was reduced to 1” by 3”. What’s up with that?
-- Steve
View pacnwguy's profile
pacnwguy
1 post in 2817 days
#10 posted 10-02-2010 02:32 AM
DO NOT BUY LUMBOO from CaliBamboo. I purchased a bunch of it for a fencing project, and the material is inferior grade. Even after applying their special protectant coating to the lumboo, it got moldy. This stuff is crap. Do not waste your $ !! I thought I was doing something good for the environment by choosing this over treated lumber. I’m sticking with the treated wood.
View harbortides2's profile
harbortides2
2 posts in 2667 days
#11 posted 02-28-2011 08:59 PM
Has anyone had a good experience with lumboo?
-- harbortides2
View Bearpie's profile
Bearpie
2601 posts in 3041 days
#12 posted 02-28-2011 10:40 PM
I picked up a stack of 3/4” bamboo flooring material that was 3+” wide and 36” long and was plastic wrapped. I ran it through my planer and edged it and cut it into 1 1/4” to glue up into a cutting board. Have not gone past this stage yet but it works out nicely although it splinters easily on cross cuts. I think once I seal it, it will look great. Very hard stuff!
Erwin, Jacksonville, FL
-- Erwin, Jacksonville, FL
View gfadvm's profile
gfadvm
14940 posts in 2713 days
#13 posted 03-01-2011 05:07 AM
I have used bamboo flooring scraps for small boxes.IT CUTS,SANDS,and routs like oak with sharp bits.Dont bear down on sander as it will delaminate if you get it over warm!
View Derek's profile
Derek
36 posts in 2636 days
#14 posted 04-02-2011 05:21 AM
Here’s a chest I did recently and am very happy with the end results of it.
http://lumberjocks.com/projects/46768
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3549 days
#15 posted 04-03-2011 05:11 AM
The folks at Cali are great but when I bought bamboo from them and brought it home to the high desert… Well, read the bamboo part of my project: http://lumberjocks.com/projects/15908
