Drying Time
Forum topic by myxology posted 07-02-2016 01:05 AM 759 views 0 times favorited 6 replies Add to Favorites Watch
View myxology's profile
myxology
60 posts in 1389 days
07-02-2016 01:05 AM
In another post a couple of weeks ago I asked if I was missing anything on how I was going to build this table. I got some great feedback and have taken all that into consideration. What I’m not sure on is wood drying time. I bought all of my boards today but it is just douglas fir that has not been kiln dried. So I’m guessing it needs to be dried out. My question: How long does it really need to dry before I can use it? And would the drying time be different if I were going to use a different construction technique, say for example, I was going to do it picnic table style where the boards would be separated instead of glued up and flattened? I posted a sketchup photo of the table again just to show the type of table. My main question is just about drying time for the boards.
View bondogaposis's profile (online now)
bondogaposis
4998 posts in 2500 days
#1 posted 07-02-2016 04:33 AM
It all depends on your climate and how thick the boards are and how they are stored. There is no definitive answer. Boards for furniture are dried down to 8% moisture content. Stack, sticker and wait.
-- Bondo Gaposis
View ksSlim's profile
ksSlim
1286 posts in 3039 days
#2 posted 07-02-2016 09:30 AM
moisture meters are not expensive. dry 6-10%. check for movement.
-- Sawdust and shavings are therapeutic
View Gene Howe's profile (online now)
Gene Howe
10914 posts in 3577 days
#3 posted 07-02-2016 02:26 PM
Stack, sticker an WEIGHT IT DOWN! Doug fir is notorious for twisting as it dries.
myxology
#4 posted 07-02-2016 03:40 PM
Thanks for the feedback everybody. Gene, how would you suggest I weight it down? Bricks on the topmost layer or something like that?
Gene Howe
#5 posted 07-02-2016 05:10 PM
I’d use 1X1 stickers every foot. Then place the weights on the top board, centered on each sticker. Try for 6-8lbs per sticker. If you use bricks or concrete blocks, you’ll want to protect the top board…scraps of carpet or towels should be good enough.
View gfadvm's profile
gfadvm
14940 posts in 2839 days
#6 posted 07-03-2016 12:20 AM
Lay a row of stickers on your top board, then lay a 2×6 on top of those stickers, and lay concrete blocks on the 2×6s. Keep your stack out of direct sunlight and keep the air circulating with a small fan.
