help with a platform bed
Forum topic by Wintersedge posted 05-01-2010 03:39 AM 3447 views 1 time favorited 3 replies Add to Favorites Watch
View Wintersedge's profile
Wintersedge
83 posts in 2936 days
05-01-2010 03:39 AM
Topic tags/keywords: modern question
I am looking to build a platform bed and looking for some help understanding the slats that support the mattress.
I have seen a few designs where the slats under the mattress bow upwards. Is there a technical reason that there is a bow? Does it provide better support for the mattress vs having flat slats?
How does one go about creating the bows? Is this something I am going to need a vacuum press and/or a steam press?
Thanks
-- Motivation alone is not enough. If you have an idiot and you motivate him, now you have a motivated idiot.
3 replies so far
13600 posts in 3303 days
#1 posted 05-01-2010 03:50 AM
if you are using a box spring ,
it has it’s own frame .
the slats are to keep it from dropping down between the rails .
flat or bowed makes no difference ,
but bow up is stronger than bow down .
it has to go past straight to get to bow down and break .
if there is no box spring ,
then a ply platform is best .
like when you sit on the bed ,
all your weight is on one or two slats ,
and they can break .
View Michael Murphy's profile
Michael Murphy
453 posts in 2967 days
#2 posted 05-01-2010 04:57 AM
Patron is right, If it’s a box spring and mattress you just have to support the edges.
If it is just a mattress, or futon, then you probably need slats pretty close together to support it. My son’s bed has a “futon” mattress out of that memory foam stuff and it has slats spaced about 2” apart attached to webbing to keep the spacing between the slats.
I would think the upward bow is just to compensate for the weight of the bed’s occupant(s).
You probably don’t need it. You just need the thing to be stiff enough that it doesnt sag in the middle.
Is it a double, single, king, queen size? If it is a wide bed, run a support lengthwise up the middle to match the height of the outer rails to support the center of the slats.
-- Michael Murphy, Woodland, CA.
View BikerDad's profile
BikerDad
335 posts in 3563 days
#3 posted 09-18-2011 08:07 AM
I’m coming to this thread wayyyyyy late probably, but still:
The bowed slat system is actually the European alternative to our box springs. It can be (and usually is) an adjustable suspension system. There are a variety of different takes on it. The basic one is explained here: http://www.sleepworks.com/mattresses/flexible-slat-system. Another take, which uses a flexible base but appears to skip on the bowing (which presents problems with Queen and King size beds) is known as Austroflex, not surprisingly by an Austrian company. For a closer look, head down to your local IKEA, assuming you have a local IKEA. I believe they have some info on their website about it as well.
-- I'm happier than a tornado in a trailer park! Grace & Peace.
