Hows it made
« back to Joinery forum
Forum topic by chaneg posted 07-01-2016 02:46 PM 822 views 0 times favorited 10 replies Add to Favorites Watch
View chaneg's profile
chaneg
8 posts in 667 days
07-01-2016 02:46 PM
Topic tags/keywords: table top bread board
I am relatively new to woodworking. I was in the store a couple months ago with my mom and she said she would like a table similar to the one shown here. My question is how do they do this mitered breadboard looking top without it getting screwed up with seasonal changes. It dosent seem like the panel would be ply with how the back lifts up to reveal a charging station. At 600 I dont think a person would lift that lid up and see the layers of plywood. So how is it made?
10 replies so far
View lew's profile
lew
12019 posts in 3723 days
#1 posted 07-01-2016 03:08 PM
Picture would help
chaneg
8 posts in 667 days
#2 posted 07-01-2016 04:31 PM
I cannot seem to post a picture I hit img and selected a photo but it dosent show up
chaneg
8 posts in 667 days
#3 posted 07-01-2016 04:32 PM
Got it
View RJweb's profile
RJweb
119 posts in 2601 days
#4 posted 07-01-2016 04:33 PM
Sorry my bad
-- Life Begins @ 190 MPH
View jdh122's profile
jdh122
996 posts in 2786 days
#5 posted 07-01-2016 04:44 PM
I bet the center panel is plywood with edgebanding. Easy enough to tell by opening the piece up (do you see end or side grain?).
There’s nothing to give a sense of scale to the table: maybe it’s small enough that the expansion won’t be much of an issue. Or maybe it’s just badly made with miters that will open up and/or cracks that will develop in the panel (if it’s solid wood).
-- Jeremy, in the Acadian forests
View BurlyBob's profile
BurlyBob
5419 posts in 2234 days
#6 posted 07-01-2016 04:47 PM
I agree with Jeremy about that being plywood. Just look at the seam in the veneer. Plain to see from here.
chaneg
8 posts in 667 days
#7 posted 07-01-2016 05:37 PM
The center panel is about 12 inches. I took the picture months ago so I don’t have access to open it now. If I knew then what I know now I would have took pic with it open
chaneg
8 posts in 667 days
#8 posted 07-01-2016 05:39 PM
What if I just made it out of solid wood? Is seeing endgrain on two edges of the table a big deal?
jdh122
#9 posted 07-01-2016 06:11 PM
Solid wood with no breadboards or mitered boards around it would be fine, probably the cleanest look as far as I’m concerned. The end grain on the edges of the table is not a disadvantage, but is the proof that you used solid wood. People use mitered construction like this to hide the fact that it’s plywood.
You might want to use some kind of a cleat screwed onto the back of the short piece just to make sure it doesn’t warp over time given it won’t be attached to the base. You would attach it perpendicular to the grain, making sure to elongate the holes in the cleat a bit so that wood movement doesn’t cause issues (unlikely to be a problem over only 16 inches, but just to be safe)
View bondogaposis's profile
bondogaposis
4688 posts in 2319 days
#10 posted 07-01-2016 06:40 PM
They used plywood for the center panel, plywood is stable, so seasonal changes do not apply on this type of construction.
-- Bondo Gaposis
