1970's model craftsman R.A.S.
Forum topic by Frankie Talarico Jr. posted 04-30-2010 01:29 PM 1563 views 0 times favorited 7 replies Add to Favorites Watch
View Frankie Talarico Jr.'s profile
353 posts in 3354 days
04-30-2010 01:29 PM
Topic tags/keywords: radial arm saw blades blade ras craftsman question tip
I have an older RAS, I actuallu had it for years but never got to set it up. I finally have room to put it up and build a bench around it. This saw is in great shape and has had little or no abuse. I’m looking into blades I should buy. a friend recommended this, 10 deg. positive hook blade with a “triple chip profile”. He says it eliminates ( or lessens) the pull of the saw. This way it don’t grab and rip right at me. He says they are much safer than a typical blade. I will only crosscut with it ( 90 degrees), and I use an array of soft and hardwoods.
Just to tickle my imagination I am wondering what type of accessories they made for saws like these. I found an article about using dadoes, making mouldings, and cutting tenions. Are these practical to appy on these saws. I know they are notorious for coming out of square when adjusted frequently.
Basically What I want to know is any kinds of useful stuff i can do with it other than crosscut. Secondly which blade would best serve my purpose for safety, and cut quality? I have used RAS plenty in the past, but now I use my own i have a million questions.
-- Live by what you believe, not what they want you to believe.
7 replies so far
View Gregn's profile
Gregn
1642 posts in 2981 days
#1 posted 04-30-2010 03:15 PM
You can put a molding head cutter, sanding disc, and a dado blade on it. you can even put a chuck on it and use it as a pin router. As for blades I generally just use crosscut blades that I have for my table saw. I have a 1958 craftsman RAS myself and would give up my SCMS before the RAS.
View Raymond's profile
Raymond
676 posts in 3725 days
#2 posted 04-30-2010 03:16 PM
I think the RAS is a great tool, I use my constantly, great for dadoes, I can’t remember what blade I use I will look and see. At one time there was a large drum sander attachemet made for these says I think it was Performax that made it, also a planer attachment, I have a drill chuck on mine and use milling cutters.
-- Ray
View davidpettinger's profile
davidpettinger
661 posts in 3198 days
#3 posted 04-30-2010 07:41 PM
I love my Craftsman RAS. I have a Freud 10” blade in mine. I also use a 7” Craftsman Dado in it, and I have a Craftsman molding head cutter that has several blade sets for it. She is on her fourth homemade tabletop and her eighth fence, but it’s a workhorse and she runs great.
-- Methods are many,Principles are few.Methods change often,Principles never do.
13603 posts in 3338 days
#4 posted 04-30-2010 07:52 PM
here is what i did ,
there are more ‘accessories’ down further in the post ,
http://lumberjocks.com/projects/21465
it is a great tool ,
use it safely .
many will comment against it ,
but for years it was the tool on all building sites .
the problem being that they were just used and abused by transient carpenters ,
the tables and back stops cut up and no out board hold ups used .
so naturally , they got a reputation for dangerous tools .
set up properly ,
they are as versatile and safe as any other tool in the shop .
#5 posted 04-30-2010 09:25 PM
Patron/David,
Nice bench I really like how it’s collapsible, and it juts out near the arm. I was trying to figure out if I want a 24” bench or just a jut-out.
I’ll never use it for ripping, ( so I say) but the moulding heads are a little intruging
Thanks for all the replies
#6 posted 04-30-2010 09:39 PM
here is more ,
for dados ,
you could do molding cutters ( crosscut ) ,
with this ,
or do your cutters (rip ) ,
without it .
http://lumberjocks.com/patron/blog/11083
when ripping with the ras ,
always lay the guard down on the work ,
to keep it from lifting ,
and always feed the wood from the
proper end ,
into the teeth , not with them ,
same as in the table saw .
#7 posted 04-30-2010 09:52 PM
Wow that second post is amazing. I really like the functionality. I guess i got a lot of learning to do….totally blew my mind, now I got stuff to build…... Thanks
