Question about Waterlox finish
Forum topic by Dj1225 posted 06-30-2016 01:24 AM 877 views 0 times favorited 10 replies Add to Favorites Watch
View Dj1225's profile
Dj1225
69 posts in 2341 days
06-30-2016 01:24 AM
Topic tags/keywords: waterlox table finish
Hi Jocks,
I need some advice. I have made a dining table out of ash and walnut that came out very nice. I have applied 4 coats of Waterlox over boiled linseed oil. Finish looks great, but my client says it is a bit too shiny. At this point I do not want to screw this up, so after the last coat is fully cured, say a week, could i wet sand with. 500 or more grit paper, to,take off the aggressive shine. If so would it be better to use a orbital sander, or sand with grain by hand.
If not any suggestions.
As always thanks for your help.
Dave
-- Dave
10 replies so far
View chrisstef's profile
chrisstef
17637 posts in 3127 days
#1 posted 06-30-2016 01:28 AM
Far from an expert here but id go by hand if i was abrading. I wonder if some synthetic steel wool and wax would knock it down enough?
View Kirk650's profile
Kirk650
553 posts in 870 days
#2 posted 06-30-2016 03:02 AM
Cure time is more like 3 weeks, so don’t rush the rub out. In your situation, I think I’d add a coat of the Waterlox satin. You might not need to rub it out. I use the satin, let it cure and then use OOOO steel wool and Johnson’s wax.
View OSU55's profile
OSU55
1835 posts in 2111 days
#3 posted 06-30-2016 12:01 PM
Synthetic or real steel wool will get a more even sheen then sandpaper because of the flexibility. Rub with the grain by hand. I have used syn steel wool with a drill and sanding pad for this as well. Using satin waterlox, or regular poly thinned 1:1, is another option. Letting it cure several weeks is best.
View Logan Windram's profile
Logan Windram
347 posts in 2583 days
#4 posted 06-30-2016 01:08 PM
Fine steel wool, and get a bottle of wood lube…
View trialrun's profile
trialrun
46 posts in 928 days
#5 posted 06-30-2016 03:21 PM
ditto, 0000 steel wool and then a satin waterlox
View Woodknack's profile
Woodknack
12341 posts in 2501 days
#6 posted 06-30-2016 04:40 PM
The additives in satin and flat are there to mimic a hand rubbed finish, doing both is a waste of time, effort and money. Use 0000 steel wool and wax, not water; or use a scratch pad if you can find one fine enough.
18869 posts in 1978 days
#7 posted 06-30-2016 04:53 PM
If it were me and I had never done a hand rubbed finish, I think I would choose to add a coat of satin instead of trying my hand with a finished table.
View ClammyBallz's profile
ClammyBallz
442 posts in 1258 days
#8 posted 06-30-2016 05:02 PM
Rubbing out a finish will give you more control on the sheen than top coating with a satin. When in doubt, finish a few scrap pieces and practice on them first. If the finish is not completely level, it’s best to start with 600-800 sandpaper first to level it out, then use 0000 wool and wax. Otherwise, just use wool & wax.
View newwoodbutcher's profile
newwoodbutcher
757 posts in 2971 days
#9 posted 06-30-2016 07:45 PM
Consider making the last few coats their semigloss product. Add. As many coats as it takes to achieve the desired luster.
-- Ken
View bobasaurus's profile
bobasaurus
3530 posts in 3305 days
#10 posted 07-01-2016 04:19 AM
Waterlox will eventually lose some of its gloss.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
