Building shop stuff
Forum topic by Knothead62 posted 04-29-2010 08:01 PM 1325 views 0 times favorited 8 replies Add to Favorites Watch
View Knothead62's profile
Knothead62
2584 posts in 2962 days
04-29-2010 08:01 PM
Topic tags/keywords: tip resource
I just called a local cabinet and countertop supplier in town. I asked what they did with the cutouts from sink installation. They toss them in the trash!. I am thinking of a top for a router table, drill press sanding setup as shown in projects today by Diggerjack. Work bench for my grandkids. Flytying table. Shelving. I’m sure the LJ folks will come up with many uses for them.
Damaged countertops are handled by their supplier, so nothing there. I’ll have to buy them.
8 replies so far
Rick Dennington
5864 posts in 3195 days
#1 posted 04-29-2010 09:40 PM
Greetings Knothead62:.... I ‘ve used several cut-outs from kitchen sinks for router table tops. They work great, are laminated, and MDF to stay straight. Most of the work is already done for you…... lol. THe only problem I have with them is that they are usually too small for my liking…. I like big tops.
Knothead62
#2 posted 04-29-2010 09:49 PM
Well, Rick…..........we could join a bunch together with duck tape and make a reeeeaaalllll big one.
Seriously, what did you use to drill through the laminate? What did you use to rout edges, etc. I’m going tomorrow and pick up a couple.
Knothead62
#3 posted 04-29-2010 10:13 PM
While perusing through the forum and projects, I thought I could square two ends and join them to make one long top for a router table. I’ll see what I can conjure up.
View scrappy's profile
scrappy
3507 posts in 3431 days
#4 posted 04-30-2010 08:48 AM
I use a cut out from a 30inch cook top. Corian. Works great.
-- Scrap Wood's the best...the projects are smaller, and so is the mess!
View Gregn's profile
Gregn
1642 posts in 2984 days
#5 posted 05-01-2010 01:43 AM
Having been a handyman I have thrown many away myself. I did make a top for my grinding station from a cutoff piece of counter top. I had no problems drilling or routing. I did though use masking tape where I made my cuts to prevent chip out during my cut.
View Brandon Hintz's profile
Brandon Hintz
53 posts in 3009 days
#6 posted 05-01-2010 01:50 AM
You can join the tops with miter bolts just from the bottom drill a hole in each piece with a forstner bit then using a router plow the groove to connect them use some polyurethane constructon adhesive between the sink cutouts and make sur the surface is properly supported.
-- Potential is limited only by imagination
Rick Dennington
#7 posted 05-01-2010 02:50 AM
Greetings Knothead: Are you talking about doing the cutout for the router plate, and the starter holes for each corner ? If so, then I used a 1/2” Brad point bit to drill all the way through. Then I used a jig saw for the through hole, and a 1/2” straight bit to cut the depth for the plate to sit in. Then drill 4 tiny holes in each corner for your leveling screws…... The Brad point won’t tear out the laminant if you’re careful. If you can get, or make a template the size of your plate, then it should be a breeze… I hope this was the question you were asking. Cut the groove for the plate to sit in about 3/8—1/2” wide for a good lip for the plate to rest on…....
View canadianchips's profile
canadianchips
2600 posts in 2998 days
#8 posted 05-01-2010 04:09 AM
Try going to places like “Habitat Restore” or “Second Chance Store”. These place have a lot of used items for sale at reasonable prices . Usually you can buy them from these places cheaper than making your own. Especially if color isn’t an issue.
