Blade Breakage
« back to Scrollsawing forum
Forum topic by Prev posted 06-29-2016 07:31 PM 727 views 0 times favorited 4 replies Add to Favorites Watch
View Prev's profile
Prev
56 posts in 1520 days
06-29-2016 07:31 PM
Hi all…
I have had my Excalibur 16”scroll saw for just over a year now and really enjoy it. It’s the best scroll saw I’ve ever had.
I just recently encountered a small problem that maybe some of you may have encountered.
I am using a Flying Dutchman Penguin Silver Reverse #2/0 blade which is my blade of choice. I just started breaking them about an inch above the lower blade clamp. I rarely break blades but this is getting to be quite regular.
Anybody have any ideas as to the problem and the fix?
Thank you,
Prev
-- Al, Fort Collins CO
View Redoak49's profile
Redoak49
3524 posts in 2133 days
#1 posted 06-29-2016 08:46 PM
What are you cutting with the blade? How long is it lasting?
That is a fairly small blade and used on lighter material.
View PaulDoug's profile
PaulDoug
1601 posts in 1848 days
#2 posted 06-29-2016 09:07 PM
I have encountered times when I swear I get a bad set of blades. If the ones you are breaking are all out of the same dozen, open another dozen to try if you can. I have never been able to test this because I put many dozen in a test tube at one time…..
I use the same blade often but I never cut any thing over 3/8” thick with them.
View Prev's profile
Prev
#3 posted 06-29-2016 10:08 PM
I have been using this size blade a long time. I don’t cut anything larger than 1/4” baltic plywood and cut small intricate cuts. The blade lasts on the average of 1/2 hour before breaking; sometimes longer.
I too put several dozen blades in a tube. I have wondered also if I get a bad batch of blades.
Thank you for your replies.
Prev
View Jim Finn's profile
Jim Finn
2680 posts in 3067 days
#4 posted 06-30-2016 12:19 AM
I have had this same experience with FD blades. I think it was a bad batch because after a while the problem went away.
-- No PHD just a DD214 Website> craftingcouple.com
