| Forum topic by bobman58 | posted 1120 days ago | 690 views | 0 times favorited | 4 replies | ![]() |
1120 days ago |
hi can anybody tell me how to drill the holes on a wheel hub do you use a indexer to get them evenly spaced or do you use a pattern thanks in advance -- robert dignam |
#1 posted 1120 days ago |
TVTA (Too Vague To Answer)... -- 温故知新 |
#2 posted 1120 days ago |
Assuming you use a drill press and fence, you could index with two pegs set into a square board. Center the hub hole on the square board, insert peg and glue it in. Another 6 hole method would be to take your square board and draw the X to find the center, as you would have done for above. Then draw lines at 60 deg from one leg of the X, intersecting the mid point. To add precision to the second method, drill the first wheel hole though both the wheel and board, remove the wheel, drill a second hole in the board on the next line (60 deg. left or right ), insert loose dowel peg, then replace the wheel, sliding the first wheel hole over the loose peg. Then you can simply repeat for the next 5 holes. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#3 posted 1120 days ago |
sorry i didnt explain myself very well i mean the radial holes that represent the wheel nuts -- robert dignam |
#4 posted 495 days ago |
I always use the pattern to make an aluminium jig. I glue the pattern on the aluminum and drill them with a drill press in exactly the right spot, if I mess up, I try again. I also drill the correct size for the axle peg in the middle. Then I just put the peg through the jig and into the wheel. Once I do one hole (nut) I put something through it to keep the jig aligned. I always get great results this way. -- Ryan |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3551 |
15789 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6161 |
