bench grinding wheel wobbles.
Forum topic by Mark posted 06-28-2016 09:09 PM 939 views 0 times favorited 9 replies Add to Favorites Watch
View Mark's profile
Mark
971 posts in 2177 days
06-28-2016 09:09 PM
I pulled the CGW blue al oxide grinding wheel off my 6” bench grinder and mounted a wire wheel. When I put the grinding wheel back on it wobbles and shakes like it was in an earth quake. It does have the plastic reducing bushings but that was never an issue before. lots of meat left on the wheel so I don’t want to chuck it. Any thoughts?
Thanks
-- Mark
9 replies so far
View dbhost's profile
dbhost
5767 posts in 3434 days
#1 posted 06-28-2016 09:43 PM
Is it one single plastic bushing or a bushing in a bushing? I had a set of white oxide wheels that shook like that at first with the OE plastic bushings. I replaced them with a single steel bushing, trued the wheel up and have been fine ever since.
I used a Geigers Solutions Wheel Dressing and Truing Solution. It wasn’t cheap, but it is well worth the expense if a truly smooth running true grinding wheel is important to you.
View Mark's profile
Mark
#2 posted 06-28-2016 10:54 PM
Thanks for the reply db. ITO has multiple bushings. One of these “one size fits all” efforts.
-- Mark
View TheFridge's profile (online now)
TheFridge
10740 posts in 1688 days
#3 posted 06-29-2016 12:02 AM
Just gotta play with it.
View rwe2156's profile
rwe2156
3171 posts in 1683 days
#4 posted 06-29-2016 12:23 AM
Those bushings are the problem. I would look for a solid bushing and replace it.
You can try rotating the wheel to different locations and retighten.
View Mark's profile
Mark
#5 posted 06-29-2016 04:21 AM
The Fridge: Your right I played with it, added a bit of black tape to fill in the voids and it’s all good.
rwe2156: Your right. that’s the best solution.
-- Mark
View waho6o9's profile
waho6o9
8523 posts in 2779 days
#6 posted 06-29-2016 04:29 AM
https://www.youtube.com/watch?v=_7OoqJN2L4Y
I made one out of walnut and it works well.
Credit to Ernie Conover, thanks Ernie
TheFridge
#7 posted 06-29-2016 04:31 AM
Good for you bud
I quit changing wheels because of that. What a pain
View HokieKen's profile
HokieKen
7127 posts in 1341 days
#8 posted 06-29-2016 03:26 PM
One other thing to check is that your arbor flange and arbor nut are both flat. But yeah, it’s normally the bushings and pretty much comes down to good bushings and finding the sweet spot.
- waho6o9
I made one years ago out of Delrin bar stock. Works great, no movement with humidity and easily machined on a woodturning lathe.
-- Kenny, SW VA, Go Hokies!!!
View JollyGreen67's profile
JollyGreen67
1676 posts in 2965 days
#9 posted 06-29-2016 04:25 PM
Chuck it . . . trash it . . . ! CGW’s are pure junk ! Norton is the only way to go.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected ! RIP 09/08/2018
