Porter Cable 693
Forum topic by degoose posted 04-28-2010 09:15 PM 1752 views 0 times favorited 17 replies Add to Favorites Watch
View degoose's profile
degoose
7245 posts in 3593 days
04-28-2010 09:15 PM
Topic tags/keywords: question
Hi guys , need some info on the Porter Cable 693 router.
Wondering if anyone has one and can give me the diameter of the plunge posts and the distance centre to centre between them..
I have an order for a Torque Workcentre as a surprise gift and I need the measurements to make the pins to attach the router to the machine..
Thanks in advance..
Lazy Larry
17 replies so far
117417 posts in 3816 days
#1 posted 04-28-2010 09:21 PM
hey Larry
Believe it or not I don’t own a 693 sorry about that.
degoose
#2 posted 04-28-2010 09:27 PM
And Y Not…LOL
View donjoe's profile
donjoe
1360 posts in 3270 days
#3 posted 04-28-2010 09:29 PM
Sorry also. I do own the 690LR though.
-- Donnie-- listen to the wood.
View Don Butler's profile
Don Butler
1092 posts in 3634 days
#4 posted 04-28-2010 09:32 PM
Jim!
I can’t believe that.
I thought you must have every model of every make since Noah.
d
-- No trees were damaged in posting this message, but thousands of electrons were seriously inconvenienced.
View Gary Fixler's profile
Gary Fixler
1001 posts in 3620 days
#5 posted 04-28-2010 09:47 PM
I am as well shocked that Jim doesn’t have one. I’ve seen the photos. It’s like a router museum/warehouse in his shop! I bet he has 3 of them and just doesn’t know it, or he can’t find them under all the other routers ;)
-- Gary, Los Angeles, video game animator
View Troy's profile
Troy
186 posts in 3302 days
#6 posted 04-28-2010 09:48 PM
I have that one, from what I can tell. I’ve had it for about 5 years. The posts are .788” in diameter. I can’t measure the exact distance between on center, but the posts are exactly 4.460” apart inner side.
-- Troy Bouffard || Master Sergeant, US Army (Retired) || http://www.birchhillwoodcrafts.com
Gary Fixler
#7 posted 04-28-2010 09:54 PM
Troy – A trick for measuring centers is to measure like edges, like left edge of one to left edge of the other. This gives you a reference point, and, for example, a place to hook a tape measure.
View Pat Cavanaugh's profile
Pat Cavanaugh
163 posts in 3610 days
#8 posted 04-28-2010 10:05 PM
Inner edge to inner edge plus the radius of each post will give the CP to CP. So, 4.460 + .788 = 5.248. And I to am shocked Jim doesn’t own one.
-- Pat - Biloxi, MS
View Woodwrecker's profile
Woodwrecker
4211 posts in 3814 days
#9 posted 04-28-2010 10:15 PM
Leave it to those Yankee LJ’s to bail you out Mate.
(I wish someone would surprise me with one of your Torque Workcentres !!)
Come on Jim, you expect us to believe that you don’t have two or three of that model, probably in different colors???
View woodsmithshop's profile
woodsmithshop
1365 posts in 3784 days
#10 posted 04-28-2010 10:18 PM
I have 4 Porter Cable routers Larry, but not the 693.
-- Smitty!!!
16281 posts in 4457 days
#11 posted 04-28-2010 10:28 PM
I’m pretty sure 690 & 693 would be identical. The last number, if I recall correctly, just designates whether it was part of a multi-base kit. So if someone has a 690 in a plunge base, that is what Larry needs.
I can get it for you in a few hours when I’m back home, Larry…. if no one jumps in before then.
View grizzman's profile
grizzman
7836 posts in 3542 days
#12 posted 04-28-2010 10:50 PM
well larry im really looking forward to my suprise gift…that was so sweet..since you cant come to the picnic…you send me a work center…....what a guy….......grizzman….....lol
-- GRIZZMAN ...[''''']
13641 posts in 3580 days
#13 posted 04-29-2010 01:24 AM
i’m comming up with 19 mm posts
and 147 mm centers .
i have the 693 router ,
and as charlie said it’s part of a set .
the plunge base says 6931 ,
the motor is 6902
the box says 693pk .
i don’t have a digital caliper ,
so maybe charlie can help more .
i did get one calculation at 148 mm centers .
sorry .
#14 posted 04-29-2010 01:42 AM
I’m coming up with 18.5 mm diameter on my digital caliper, and 150 mm o.c.
I hope between David’s measurements and mine this is close enough for Australian government work. :-)
View Ger21's profile
Ger21
1075 posts in 3370 days
#15 posted 04-29-2010 03:15 AM
18.5mm posts and 147.1mm OC, according to my digital Starrett.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
